Pocket GPS World :: View topic - Camera update problem.
Goto page Previous  1, 2
JockTamsonsBairn
PostPosted: Sun Feb 11, 2007 11:27 pm    Post subject: Reply with quote
Ricko61 wrote:
My favorites, home page and camera settings (warn when near) disappear every time I turn the PDA off!
1. Are you exiting from TT cleanly, using "Exit application"?
2. Is the lock on your SD card locked?
3. Is the .CFG file locked?
Jock
Ricko61
PostPosted: Mon Feb 12, 2007 8:32 am    Post subject: Reply with quote
I'm exiting correctly and the cards not locked. Where's the .cfg file and how do I know if its locked?
Ricko61
PostPosted: Mon Feb 12, 2007 8:38 am    Post subject: Reply with quote
I've just noticed that the recent destinations list is empty as well.
JockTamsonsBairn
PostPosted: Mon Feb 12, 2007 10:07 am    Post subject: Reply with quote
From your previous listing, "Great_Britain-Map.cfg". You'll need to check this from your PC. Right click and check the file properties. If it is "Read-only", change it. You may have to copy the file to your PC, change it & copy it back.
Definitely sounds like something is stopping the .CFG being updated.
Jock
Ricko61
PostPosted: Mon Feb 12, 2007 6:06 pm    Post subject: Reply with quote
Thanks BGF thats done it. It seems to be working fine now.
I could have messed about with it for the rest of my life and not sussed that out.
Cheers again
Steve
JockTamsonsBairn
PostPosted: Mon Feb 12, 2007 10:02 pm    Post subject: Reply with quote
Cheers again
Steve
Thumbs Up
Jock
Ricko61
PostPosted: Wed Feb 14, 2007 6:38 pm    Post subject: Reply with quote
Arrggggg!! its happened again with todays update.
Right, at least I know how to sort it out, but what the hell am I doing wrong? I downloaded the zip file, extracted all files to a directory. Copied the contents of the directory to the pda Great Britain directory - Do you want to replace etc. etc. - yes to all - Bloody bells and whistles again.
Must be something obvious.
Oldboy
PostPosted: Wed Feb 14, 2007 8:06 pm    Post subject: Reply with quote
When you have the warnings set up as you want them, copy the cfg File in the Map Folder, to somewhere safe on the Device.
The if it happens again just copy the Backed Up File to the Map Folder.Smile
You will then, of course, have lost any other settings you might have made in the meantime.Sad
Ricko61
PostPosted: Wed Feb 14, 2007 8:55 pm    Post subject: Reply with quote
Thanks Oldboy, but its not the cfg problem (now sorted); its downloading and overwriting the new camera data files. it seems that when I copy the new files (ov2 and bitmap)somehow the ogg files get corrupted and I have to delete and reload them as well.
Oldboy
PostPosted: Thu Feb 15, 2007 8:16 am    Post subject: Reply with quote
You don't need to copy the bmp files again.
Try making the ogg files Read-Only. This would stop them being 'corrupted'.
Ricko61
PostPosted: Tue Feb 20, 2007 7:48 pm    Post subject: Reply with quote
Thanks for the reply Oldboy. I'll give it a try.
Page 2 of 2
