showard Occasional Visitor
Joined: Dec 21, 2006 Posts: 9 Location: Cambridgeshire
Posted: Mon Jan 29, 2007 2:39 pm Post subject: Converting POI Files |
Hi all,
Maybe a bit off topic here (and a newbie) but if I am then please forgive and redirect me
How can I convert a POI file from csv (POIEdit) into a format recognised by my Mio C510E (mtc file?) and where does it go in the directory structure.
Any help links etc. gratefully recieved.
Regards
Stan |
ernest_mio Regular Visitor
![](modules/Forums/images/avatars/gallery/familyguy2.jpg)
Posted: Tue Jan 30, 2007 12:46 am Post subject: |
Thanks Ernest.
Have had a quick look, and it appears to be promising. Probably a weekend job when I have more time to study the process in depth.
Regards
Stan |
Posted: Tue Jan 30, 2007 6:49 pm Post subject: |
showard wrote: | Thanks Ernest.
Regards
Stan |
No problems - if downlaoding poi explorer dont forget to check PC has .net framework as well. |
Posted: Wed Jan 31, 2007 2:15 pm Post subject: |
Ernest,
No problem, I am a Visual Basic programmer trying to convert to .Net so the files are already installed at each Windows update.
I had another go at this last night and managed to decode the Igo.db into kml format. Looked at the kml file in notepad (easiest way to look at XML type code) and it only appears to be 1KB in size and only contains the XML version, a URL for Google Earth and the name iGO POI, all in XML format (which I can't remember how to delimit so it shows as text in a post)
Admittedly, I didn't spend too much time with this as I was trying to cook dinner.
Is this correct, i.e. poiconvert is generating an empty file for me to populate or have I messed up?
Regards
Stan |
Posted: Wed Jan 31, 2007 6:10 pm Post subject: |
showard wrote: | Ernest,
Regards
Stan |
Stan - sounds iffy to me. I use the transfer hack to store a version on my pc - 624 KB (638,976 bytes). Then import the database using IGO POI Explorer. IGO POI Explorer can import from various differnt POI formats but I have had issues with XML/Google earth so have steered clear. |
Posted: Wed Jan 31, 2007 8:56 pm Post subject: |
Ernest,
My database file is part of a backup from the original MioMap on the C510E (no mods). I did a complete backup of 'My Flash Disk' using the Transfer Hack.
The only copy of IGO POI Explorer I have found so far is a beta version which crashes all the time. I'll go go a Google for another copy.
Regards
Stan |
Posted: Wed Jan 31, 2007 9:16 pm Post subject: |
Ernest,
Can't find anything apart from the beta version which crashes with the "send error report" if I try to do anything
Stan |
Posted: Thu Feb 01, 2007 6:37 pm Post subject: |
Stan |
Sounds like you have a .net issue - other have reported this before and the fix was to check the .net installation. This information is buried in the thread inidcated earlier = search for answers from sallyann. |
Posted: Fri Feb 02, 2007 8:40 pm Post subject: |
Ernest,
OK, now I have managed to get iGO POI Explorer running without crashing. I did this by installing ActiveSync and it now has a message on the status bar as 'Device Not Connected' rather than 'ActiveSync Not Found'
Next problem, I go to File, Import, select the copy of IGO.db and nothing, no entries, just nothing.
I will search around for answers but if you know what I am doing wrong then please let me know as I have the notify set on this thread.
Stan |
Posted: Sat Feb 03, 2007 1:11 pm Post subject: |
Connect Mio to PC using USB cable.
Run Mio xfer hack.
Xfer screen appears on Mio and flash root directory appears on left on PC screen.
On MIO Devices side of screen:
Select My Flash Disk directory
Select MIOMAP
Select MIOMAP
Scroll down to igo.db (mine is 642KB)
Highlight onPC side area you want to save a copy of the file.
Select the right to left arrow - "syncronisation was successful"
Select the tick and exit MIO Xfer HACK.
Open IGO POI EXplorer
File, Import, Import database from file (offline)
Navigate to where you stored the copy of igo.db and select this.
Database should then be imported - its not quick!!
left hand panel will then showe all the MY POI data created.
I then use the file import to include various files downloaded from the internet. I have not been successful with google earth so tend towards ascii or csv format.
IGO POI explorer will put the imported file at the bottom of the list - you need to drag this up above the sync recyle bin to get it included in the file ready for export.
If this process fails alonfg the line then you have reached the limit of my knowledge I'm afraid - I poke and hope rather than confessing to being an expert - ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
Posted: Sun Feb 04, 2007 11:45 am Post subject: |
Ernest,
Finally managed to crack this. I am now able to download POI files, convert them and transfer them to the IGO.db file.
Thenks for all of your help.
Regards
Stan |
