Pocket GPS World :: View topic - Nuvi 310 Problem
Nuvi 310 Problem
Goto page 1, 2, 3, 4, 5  Next
imakora
PostPosted: Sun Jan 21, 2007 4:46 pm    Post subject: Nuvi 310 Problem Reply with quote
Hi All,
Having sorted out the audi problem I had with my Nuvi 310, I ran Ashe's latest version of Camera Manager. I used the POI uploader, and now cannot use the unit. If I switch it on when plugged in, it gets to "loading maps" and hangs. If I reset, the same happens. If I unplug the unit from the power source, it switches off. If I start on battery power, it gets to "loading maps" and then turns off. Resetting has no effect, erasing all user data, has no effect. If I hold down the start button it goes into boot mode, but again, has no effect. The Nuvi is no longer visible when I plug it into my laptop. (XP). Before I phone Garmin tomoorow, have any of you any ideas?
Regards, Ian.
djben9
PostPosted: Sun Jan 21, 2007 5:06 pm    Post subject: Reply with quote
i think that is just a case for the support team to be honest, i have the same version but its working fine with the Cam manager and POI loader, it can take a little while after loading maps sometimes after updating but only about 20 secs ?
djben9
PostPosted: Wed Jan 31, 2007 6:42 pm    Post subject: Reply with quote
did you get this fixed??
imakora
PostPosted: Wed Jan 31, 2007 10:56 pm    Post subject: Reply with quote
No, I'm sending the unit off to Garmin tomorrow for repair!
Wavesportzg
PostPosted: Tue Feb 06, 2007 7:26 pm    Post subject: Nuvi 310D Gone wrong! Reply with quote
Mines just done the same mate Sad
Am not impressed either, sending mine back tommorrow also..
mike
imakora
PostPosted: Wed Feb 07, 2007 1:20 pm    Post subject: Reply with quote
I've just had a brand new Nuvi 310 delivered as a replacement for my "frozen" Nuvi. Garmin have advised me not to use the Pocket GPS World Speed Camera Database or Ashes Camera Mnagaer until they can find out what caused the crash.
swing
PostPosted: Wed Feb 07, 2007 4:47 pm    Post subject: Reply with quote
Although I can understand Garmin's viewpoint (ignoring the fact they sell a competing camera database for which they want revenue) I don't believe anyone who has only installed the PGPSW speed camera database (directly, or via Ash's utility) has ever suffered from this problem - the problem is caused if you download the POIs and apply them, and then only (it appears) if you load too many POIs.
My Nuvi has, at times, had roughly 50,000 POIs loaded onto it without problem.
Can you confirm whether you only had the PGPSW camera database in your POI directory, or what else you had / have in there...?
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
imakora
PostPosted: Wed Feb 07, 2007 5:39 pm    Post subject: Reply with quote
I had the PGPSW camera database, the Garmin POI database from the MaFt site, and Ash's utility. I'm reluctant to install any of them again, as my Nuvi was rendered useless,and had to be replaced. I'm not sure what it was that resulted in the crash, but I await Garmin's response with interest.
swing
PostPosted: Wed Feb 07, 2007 6:42 pm    Post subject: Reply with quote
Hmm - that is interesting - you are the first person who I've personally heard of who didn't have the large POI database from this site loaded when your Nuvi died. Having said I've had over 50,000 POIs loaded, I haven't personally used Ash's utility alongside the new Category POI support, although I don't see how either could have impacted the other.
imakora
PostPosted: Wed Feb 07, 2007 7:26 pm    Post subject: Reply with quote
No, you are absolutely right. I did have this sites database loaded. Temp senior moment there.
Wavesportzg
PostPosted: Wed Feb 07, 2007 7:35 pm    Post subject: Garmin Nuvi 310D Reply with quote
Swing,
In reply to your message on another thread (but regarding the exact same issue)
I don't know exactly how many POIs i had installed but i installed the PGPS points of interest when i got the unit a couple of weeks ago, then i downloaded them again monday night to get any updates. I had already installed the latest camera database that evening, and my nuvi was working fine after, but when i installed the POI database it went wrong.
I'm fairly new to this GPS stuff, so i hope this helps..
Posted my nuvi back today to the following address
Unit 5
Quadrangle
Abbey Park Industrial Estate
Ramsey
Hampshire
S051 9DL
But first you have to ring this number and obtain a reference number
08708501242. and dont forget to send the nuvi recorded delivery this cost me about £3.90.
Mike
swing
PostPosted: Wed Feb 07, 2007 9:38 pm    Post subject: Reply with quote
No problem - from one point of view it's nice to hear it wasn't the speed camera or MaFt's POI site at fault, but equally, I think the unit should be able to fail more gracefully than this.
Louie7
PostPosted: Thu Feb 08, 2007 12:52 am    Post subject: Reply with quote
I do not download POI files directly to the Nuvi. I have purchased a SD card and use POI Loader to download the POI files to the card.
When i turn on the Nuvi it detects the new POI file on the SD card and asks if i wish to copy the information to the Nuvi. I always say no and also touch the on screen box which says do not ask again (this stops the Nuvi from asking the same question every time it is switched on. Until a new POI file is detected).
Should a problem occur with my POIs, i can simply remove the SD card and run the Nuvi without the POI files loaded.
I also use this approach when downloading MP3 files.
I would also strongly suggest you backup all the files and folders from our Nuvi to your PC. I even burn my backups to CD. You will need to switch on, show hidden files in Explorer as one file is a hidden file. If anything should then happen to your Nuvi files, at least you will be able to restore them from your backup.
imakora
PostPosted: Mon Feb 19, 2007 8:24 pm    Post subject: Reply with quote
Mike,
Have you had any feedback from Garmin on what caused the unit to crash? I've yet to hear a thing.
Regards, Ian.
dougproctor
PostPosted: Mon Feb 19, 2007 11:13 pm    Post subject: Reply with quote
I have exactly the same problem with my second unit in two months. All I did was put the 24 speed camera files from here in a folder, added quite a few POI's from here also and used POI Loader to generate a file. It told me it had loaded them successfully. I disconnected my 660, and got the message "loading maps"and shutdown with no power attached or a loading maps staying on with power.
Exactly the same as the first one three weeks ago.
Returned that to Garmin through Halfords, got given another and the same thing again last night. There must be a fault somewhere here, why don't Garmin admit it? Is it a POI problem? I used their Loader from their own site.
Mine is with a "Halfords specialist" tonight who is going to try and sort out what has happened. If no joy, I am returning and getting a TomTom 910 in its place.
If I find out what has happened tomorrow, I will make a new thread on it because it sure is affecting lots of people.
Page 1 of 5
22.093 (18 Sep 24)
