GrahamCoupar Occasional Visitor
Posted: Sun Jan 07, 2007 5:25 pm Post subject: Update |
I purchased a garmin C310 last April and downloaded the speed cam. database from this web site. This work great. It picked up all cameras, identified the speed limit and named what type of camera. Over xmas I decided to update. The version now does not pick up all cameras and only identifies the speed limit (and not what type) on those that it does detect.
I couldnt care less about the type of camera but it does show that I must have downloaded the wrong file. In simple terms, I just need to know which of the various datbases to select to get back to the reliable database I had a month ago??
GC |
Posted: Sun Jan 07, 2007 5:38 pm Post subject: |
You want the Speed zoned 24 file set - this gives the camera type and speed related information - Mike |
tanda Lifetime Member
Joined: Aug 21, 2005 Posts: 617 Location: Gloucester UK
Posted: Sun Jan 07, 2007 5:46 pm Post subject: |
I copied this from the speed camera page,
Single File: Contains all the speed cameras in a single file irrespective of type. As stated above, this category contains all of the above categories, except for the Continental one. It is for UK users who have SatNav systems that can only use a limited number of POI categories at time:
pocketgps_uk_sc
Consolidated by Type: Contains one file for each type of speed camera. This is just the main categories and none of the subcategories that show speed limits:
pocketgps_uk_gatso
pocketgps_uk_mobile
pocketgps_uk_redlight
pocketgps_uk_specs
pocketgps_uk_temp
Speed Zoned: Contains the speed cameras in individual files for each speed limit and each camera type. If you want the above but with subcategories of the Gatso, Mobile, and SPECS databases to show speed related cameras:
pocketgps_uk_gatso_20
pocketgps_uk_gatso_30
pocketgps_uk_gatso_40
pocketgps_uk_gatso_50
pocketgps_uk_gatso_60
pocketgps_uk_gatso_70
pocketgps_uk_gatso_tba
pocketgps_uk_gatso_var
pocketgps_uk_mobile_20
pocketgps_uk_mobile_30
pocketgps_uk_mobile_40
pocketgps_uk_mobile_50
pocketgps_uk_mobile_60
pocketgps_uk_mobile_70
pocketgps_uk_mobile_tba
pocketgps_uk_specs_20
pocketgps_uk_specs_30
pocketgps_uk_specs_40
pocketgps_uk_specs_50
pocketgps_uk_specs_60
pocketgps_uk_specs_70
pocketgps_uk_specs_tba
pocketgps_uk_temp
If you downloaded loads of files, it was probably the speed zoned file, If you downloaded 5 files,it was the consolidated. Make sure you download and install ALL the files from each database, All 3 databases contain ALL the cameras, as long as you have downloaded/installed all the files from either the zoned file or the consolidated. Some people mix them up and leave mobiles out or whatever, I just use the single file, quick and easy. _________________ Audi A3 Sline sat nav |
Posted: Sat Jan 13, 2007 12:57 am Post subject: |
Thanks but still no joy....
Downloads still miss the vast majority of cameras.
The first time I loaded the database (April 06) I used the Camera Manager from Ash 10, which was very helpful. When I click on this icon it closes quickly and no longer appears to function.
This time I have downloaded speed zoned 24 file as you recommend (i.e. the third file shown on the list) saved to the desk top, run the Garmin POI, it tells me it has updated 23,000+ files but when you use, the vast majority of cameras are not picked up.
Any help appreciated but please in plain english - I have no knowledge or interest in databases, just a satnav that used to work perfect and is now next to useless...
GC |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15146 Location: Bradford, West Yorkshire
Posted: Sat Jan 13, 2007 12:50 pm Post subject: |
GrahamCoupar wrote: |
in your list of custom points do you have cetegories called pocketgps_xxxx etc? if not then you have not installed the camera database. you need to make sure you unzip the file that you download and put it in the same folder as any other poi's you wish to load. then run poi loader
MaFt |
Posted: Sat Jan 13, 2007 8:45 pm Post subject: |
Yes, I have downloaded the database advised in the first reply from my posting. I get this by selecting Garmin than selecting the spped zoned 24 file. I save to desktop and then unzip (so I can see all of the files in either bmp or csv.
I then connect the sat nav to the pc which boots POI. This thinks for a miunte or so and then says congrats you have updated files (or something to that effect).
Downloaded the 24 zoned database yesterday (as recommended), went to the shops today and it completey missed two Truvelo machines that the former database I had picked up every time.
It must be something Im doing wrong but I appear to have followed your advice and still cant get reliable speed camera recognition.
Any more thoughts appreciated. |
Posted: Sun Jan 14, 2007 3:32 am Post subject: |
GrahamCoupar wrote: | Yes, I have downloaded the database advised in the first reply from my posting. I get this by selecting Garmin than selecting the spped zoned 24 file. I save to desktop and then unzip (so I can see all of the files in either bmp or csv. |
have you unzipped the file rather than just double clicking it? right-click it and choose 'extract all files' (or similar wording) then make sure the csv's and bmp's go in the same folder as any other poi files you have.
also, i'll ask again: in your list of custom points do you have cetegories called pocketgps_xxxx etc?
MaFt |
Posted: Sun Jan 21, 2007 3:37 pm Post subject: |
Yes, unzipped can see all of the files e.g. pocketgps_uk_gatso_50.bmp. I then connect to Garmin, POI loader starts, after 3 or so mins it says it has loaded x thousand of files.
But still misses 75% of cameras and only warns when entering a differing spped zone, which is of very limited value??? |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Sun Jan 21, 2007 3:57 pm Post subject: |
GrahamCoupar wrote: | Yes, unzipped can see all of the files e.g. pocketgps_uk_gatso_50.bmp. |
Graham, this isn't what MaFt is asking you.
MaFt wrote: | also, i'll ask again: in your list of custom points do you have cetegories called pocketgps_xxxx etc? |
Turn on you device. Go to the POIs (I don't have a C310 but on the i3 it's 'Where To?', 'Food, Hotels, and More', Custom Points'). If you have loaded the speed zoned files you should have 25 categories beginning pocketgps_uk_, the first of which is pocketgps_uk_gatso_20. Do these appear on your C310? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Posted: Thu Jan 25, 2007 1:15 pm Post subject: |
Anita,
Thanks for explaining more clearly. Yes, can see all 24 files starting with 20 & ending with pocketgps-uk-temp.
Problem is though, still doesnt recognise most cameras and no longer names camera and gives a max speed (Im not at all bothered about names but it does show database loaded is not the one I have in for last 9 months that was very accurate.
Any thoughts?
Graham |
Posted: Mon Feb 05, 2007 10:19 am Post subject: |
O.K - have to admit defeat on this, if nothing else spending too much time on this when could be doing something far more interesting.
Have followed all below (or above) advice and still misses 75% of cameras. Is there anywhere I can send the machine to have it loaded correctly?? |
SpikeyMikey Lifetime Member
Joined: Mar 21, 2006 Posts: 854 Location: Hertfordshire. Forever blowing bubbles
Posted: Tue Feb 06, 2007 12:56 pm Post subject: |
Where are you based, or do you get around? (Sorry to be so personal ) _________________ Mike
TT GO6000 (Europe); iPhone and iPad Pro with iOS TT GO & MyDrive + CamerAlert |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Tue Feb 06, 2007 1:28 pm Post subject: |
You might want to check the settings - something like Settings/Proximity Alerts. You will need to ensure the "Custom POI" option is ticked, and any "Garmin Safety Camera" option is unticked. Also, if there is an Option or Alerts option - ensure it is set to "Continuous Speed Alerts" - it sounds possibly like you are getting alerts on the Garmin sample database that might be installed, and not getting alerts on the PGPSW one.... _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
