Pocket GPS World :: View topic - HP6340 & TT6 Bluetooth config problem
notsundancekid
PostPosted: Fri Jan 19, 2007 11:46 am    Post subject: HP6340 & TT6 Bluetooth config problem Reply with quote
Can any one help me with the following problem.
I have a HP IPAQ 6340 PDA with both Copilot 5 and TT6, and have previously used the Copilot BT GPS receiver successfully with both.
However I've recently experienced some lock up issues whilst running TT6 and realised that my PDA firmware was very out of date. I therefore upgraded to the latest version (1.11.10).
Unfortunately I now can not get a GPS signal when using TT6, yet the same set up works perfectly with Copilot.
On the TT6 GPS screen I've tried using both of the Bluetooth options i.e. COM4 and COM7, when the IPAQ Bluetooth Manager shows a connection to the GPS receiver.
I've trawled this site for help, and there is some advice for 69xx series users regarding some serious reg edit stuff, but this is for internal GPS receivers.
Its very fustrating that the hardware works with Copilot (not preferred - never realeased the traffic option on v5 !!!!) and not TT6.
Any help or advice appreciated.
PostPosted: Fri Jan 19, 2007 12:22 pm    Post subject: Reply with quote
Welcome to the forum, can you try going to Start/ Settings/ System TAB, tap the memory icon then Running Programs TAB, make sure no GPS related program is still running, to make sure press Stop all.
Now run up TomTom and see if you can get the GPS to work, when you have selected the GPS does the little yellow blue disk top right of the screen spin? - this is found on the GPS Status page - if its not spinning try another setting. What actual choices are you making within the TomTom GPS set-up screens? - Mike
notsundancekid
PostPosted: Fri Jan 19, 2007 3:21 pm    Post subject: Reply with quote
Mike,
I've did as you suggested. Only Activesync & File Explorer appeared to be running, but I did a stop all applications any way.
I' restarted TT6 and it works !!! I've exited and restarted TT6 2 or 3 times and it has auto connected to the GPS on each occassion.
Even tried to recreate the problem by using Copilot, exit swap SD card, and use TT, but problem didn't recur.
Strange or what !! Next time I'll use the forum sooner - it might save we wasting a couple of hours. Thanks for your help - much appreciated.
22.062 (12 Jun 24)
