nickmon Occasional Visitor
Posted: Mon Jan 15, 2007 1:21 pm Post subject: Which GPS system shows current car speed on screen? |
Does anyone know if any GPS system (other than TomTom!) that will show the current car speed on the display screen as you drive? |
nivek22 Lifetime Member
Joined: Mar 09, 2006 Posts: 194 Location: Barnsley, South Yorkshire.
Posted: Mon Jan 15, 2007 1:39 pm Post subject: |
CoPilot |
Teddy_Bear Regular Visitor
Joined: Oct 25, 2006 Posts: 87 Location: warning have moved to leyland :D
Posted: Mon Jan 15, 2007 1:52 pm Post subject: |
Yes the mio units the raodangelnavigator
Not sure on the garmin,They will show speed but some only when not navigating.
The navcam will show speed too. _________________ truckdriver site www.truckerplace.eu
OFFICIAL PGPSW TEDDYBEAR  |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Mon Jan 15, 2007 1:58 pm Post subject: |
Many of the Garmin units will show it in big numbers on the trip computer screen. When you come to a turn, a pop-up picture of the intersection appears.
You can see the manuals with screenshots on Garmin's website.
Some Garmin units allow you to customise the map page to show the speed too. _________________ Gone fishing! |
PaulH66 Occasional Visitor
Posted: Wed Jan 17, 2007 12:45 am Post subject: |
Mio C510E (which I have) and probably the other recent Mio's. _________________ Mio C510E v3.2 (with European maps on 1GB SD card) |
steviebilbo Lifetime Member
Joined: Jan 01, 2007 Posts: 54 Location: Ferndown, Dorset
Posted: Wed Jan 17, 2007 5:42 pm Post subject: |
The Navman N series (at least my N40i) displays road speed and very accurately too!
Steve B _________________ "Better to remain silent and be considered a fool than to open ones mouth and remove all doubt"! |
classy56 Frequent Visitor
Posted: Fri Jan 19, 2007 9:01 am Post subject: |
steviebilbo wrote: | The Navman N series (at least my N40i) displays road speed and very accurately too!
Steve B |
How do you know it's very accurate?
I'm asking because I am having ongoing problems with a garage regarding my vehicles speed and its limiter. _________________ Tomtom Go730T
App 8.300
Map v815.2003
To old to die young. |
Posted: Fri Jan 19, 2007 11:36 am Post subject: |
classy56 wrote: | How do you know it's very accurate? I'm asking because I am having ongoing problems with a garage regarding my vehicles speed and its limiter. |
There was a fairly long discussion of this in this thread.
To summarise: Most GPS manufacturers claim an accuracy of .1 mph on flat ground at constant speed and direction with a good GPS fix. The sat nav system displays the speed it gets from the GPS so it is usually very accurate.
If there is a dispute with your garage then take them for a (white knuckle?) ride and show them the speed on the GPS.
Alternatively, you can print out the GPS chipset specifications (probably a SiRF chipset?) and they state how accurate the speed is. _________________ Gone fishing! |
missing_user
Posted: Fri Jan 19, 2007 11:55 am Post subject: Re: Which GPS system shows current car speed on screen? |
nickmon wrote: | Does anyone know if any GPS system (other than TomTom!) that will show the current car speed on the display screen as you drive? |
My Garmin 60CSX does that and records your journey/track with relevant speeds [every few seconds] and all that can be transferred to the PC! |
Posted: Fri Jan 19, 2007 12:45 pm Post subject: |
classy56 wrote: | I'm asking because I am having ongoing problems with a garage regarding my vehicles speed and its limiter. | You could try loading a third party application to the 710 which gives it the capability to datalog.
The while in the suspect vehicle datalog a trip when at max speed (a couple of minutes should be all you need). Then use the data to produce a printed report of Lat/ Long and Speed. You will soon see if the vehicle is not speed limitting correctly, and give the mechanic the print out to prove it. Have a look at THIS - as allways with third party applications make sure you back up your device BEFORE loading or trying this.
I use the logger on my 910 quite often, the data oututs can be manipulated into other forms of GPS related traces using GPSBABLE - Mike |
waughie Occasional Visitor
Joined: Dec 15, 2006 Posts: 17 Location: Stoke on Trent
Posted: Fri Jan 19, 2007 1:19 pm Post subject: |
The NAVMAN PiN 570 also shows the speed that you are doing on the screen.
It has the option of Time to distance, Distance Travelled, Speed and other ones. |
