djmagic Occasional Visitor
Posted: Mon Jan 15, 2007 9:34 pm Post subject: can i test my tomtom one |
hello ....
i have a tomtom one and have updated the software using tomtom home..
but my problem is i am no longer allerted of speed cameras or any poi's ...i have set them up with bells etc and enabled them and so on but i get no warning
if i update my card (re-write) will this make a difference
and how can i test it other than getting in my car and driving to a speed camera or any poi..
hope htis makes sence |
Posted: Mon Jan 15, 2007 9:50 pm Post subject: |
Use Advanced Planning to set a departure and destination point make sure the route passes a local camera, then route demo to play it back (set the speed to 100% - ish).
I assume you used to have warnings of cameras prior to the update - which Speed Camera database are you using the one from this site or the TomTom offering? - Mike |
Posted: Mon Jan 15, 2007 10:11 pm Post subject: |
thanks for the help
have tried what u suggested
but no warning soud made
any other suggestions..please |
Posted: Mon Jan 15, 2007 10:13 pm Post subject: |
mikealder wrote: | I assume you used to have warnings of cameras prior to the update - which Speed Camera database are you using the one from this site or the TomTom offering? - Mike | Perhaps an answer to this question might be in order to go further?? - Mike |
Posted: Mon Jan 15, 2007 10:14 pm Post subject: |
from this site
and mcdonallds from another site |
Posted: Mon Jan 15, 2007 10:23 pm Post subject: |
With the POI files in the map folder you need to go to Change Preferences/ Manage POI/ Warn When Near POI select EACH camera in turn and configure the warnings, sound/ distance/ POI on Route (or not) this must be done for each camera category you have loaded.
Make sure you don't have the volume turned down.
I also notice you mention upgrading the software - did this involve a map upgrade? - if so have you selected the new map and are the POI files in the new map folder? - in addition once the new map is selected you will need to set-up the warnings once it is selected - Mike |
Posted: Mon Jan 15, 2007 10:43 pm Post subject: |
all setting are ok
poi all have a sound
all files are in the map folder
i get a symbol saying speed camera or church etc etc
but still no sound?!!
i do get a voice giving me instruction |
Posted: Mon Jan 15, 2007 10:52 pm Post subject: |
Does the icon that appears come up on the map or in the top left corner of the display flashing as well? - Mike |
Posted: Mon Jan 15, 2007 11:17 pm Post subject: |
its fixed
did a reset
inserted my original card
tried it with no warnings
inserted my other card and now its works
hope i didnt waste ya time and thanks forr the help |
Posted: Sun Jan 21, 2007 9:12 pm Post subject: |
again i have a problem...
i have no warnings again
the symbol does not flash in the corner of the screen when passing a camera
but does when i pass a railway station and i also get a sound..
have i installed the cameras incorrectley
Posted: Sun Jan 21, 2007 10:59 pm Post subject: |
well have managed to fix the problem up to now but dontknow how...
i have just downloaded and installed an update tomtom application 8.2mb
now the camera flashes in the corner of the screen but no sound...i have allocated a sound for this camera atc atc.. just cant work it out
it worked fine b4 the update
any help please |
