Pocket GPS World :: View topic - TomTom 6 on IPAQ 5550 "no maps found"
bluejaybee47
PostPosted: Wed Jan 10, 2007 6:32 am    Post subject: TomTom 6 on IPAQ 5550 "no maps found" Reply with quote
I read with pleasure that people have TT6 running on IPAQ 5550 under WM2003 from an SD card.
I have Navman sleeve on 5550 with 1Gb SD. I tried loading eveything onto the SD card but no matter what I reorganise I always get "No maps found".
Can anyone help?
MrT
PostPosted: Wed Jan 10, 2007 8:15 am    Post subject: Reply with quote
I have no idea about the Navman sleeve but everything on my 5550 works when installed from the DVD to the 5550 with a 4GB SD card in its slot.
Is your installed from the DVD via TomTom Home or did you buy it pre-installed on an SD card?
Some of the versions found on ebay have this issue.
bluejaybee47
PostPosted: Wed Jan 10, 2007 9:11 am    Post subject: Reply with quote
Thanks for responding. It came loaded on the SD card. I read some of the ideas like putting the maps in a my documenst folder on the SD card but so far no joy.
Any further thoughts?
Tim Buxton
PostPosted: Wed Jan 10, 2007 9:13 am    Post subject: Reply with quote
So what directory are the maps in? Is this an official TomTom SD card?
Tim
MrT
PostPosted: Wed Jan 10, 2007 10:34 am    Post subject: Reply with quote
If the 2577 folder (with the autostart and cab files) is removed from the root of the SD Card on my PDA, the maps are not found.
cgavula
PostPosted: Wed Jan 10, 2007 4:23 pm    Post subject: Reply with quote
Does the Navman sleeve have a card slot as well (maybe a CF slot)? Is there a card in it? If so, try removing the card from the Navman sleeve. TT6 has problems sometimes with multiple-card devices. It can't seem to search for the maps correctly when there is a card in the second slot. THe SD slot in you 5550 would, of course, be the first slot.
I know some sleeves had that CF card slot.
--Chris
philpugh
PostPosted: Wed Jan 10, 2007 5:58 pm    Post subject: Reply with quote
Interesting. When I "upgraded" from 5.21 to 6 using a download from the TT web site I placed an empty card in the SD slot as it complained there wasn't enough room for the maps on the existing one - which was correct. Using TTHOME it installed the Maps onto this SD card and there is no 2577 folder on the card. Of course it does mean that I have to manually start TT on the PDA when I insert the card - but I don't mind this. All I have on the SD card are Voices, Western Euroe and ZIP.
MrT
PostPosted: Thu Jan 11, 2007 9:40 am    Post subject: Reply with quote
My TomTom6 will not find any maps unless there is a file called autorun.exe in the "storage card\2577" directory. It does not matter what the autorun.exe file is, it just looks to see if that a file with that name is there. Mine is now a blank file so it does not autorun when I insert the storage card.
bluejaybee47
PostPosted: Sun Jan 14, 2007 1:04 pm    Post subject: TomTom 6 on IPAQ 5550 "no maps found" Reply with quote
Thanks for all the suggestions. I have come to the conclusion that the SD card is cactus, so will have to start again.
