Pocket GPS World :: View topic - Fugawi Uk and palm Tunsten 3
paulst
PostPosted: Tue Feb 10, 2004 11:54 am    Post subject: Fugawi Uk and palm Tunsten 3 Reply with quote
Hello,
I am using Fugawi UK 3.1.0.473 and a Palm Tungsten T3 .
Whenever I start a route and click on Navigate on the palm it beeps and crashes and needs a soft reset. It appears to be trying to display something on the screen as I can see parts of a very faint image when it crashes.
Otherwise I can drag and scroll maps fine.
Also Waypoints have no names displayed beside them on the Palm just the waypoint square appears.
Anyone have any help or suggestions or similar problems.
The software mentions the Garmin ique so I thought it would support the T3 but maybe this is not the case.
Thankyou,
Paul
PostPosted: Tue Feb 10, 2004 3:02 pm    Post subject: Reply with quote
Paul,
I have just tried the same with my Tungsten T3 in both the extended and smaller screens. Fugawi crashes in both situations.
This has to be a problem where the software has run over some operating system data and trashed the PDA memory.
paulst
PostPosted: Wed Feb 11, 2004 10:17 am    Post subject: Reply with quote
Mike,
Thanks for checking this out. I re-installed and applied the update from the fugawi website (although it is the same version) just in case I was using older version of palm files but same problem occured. I have emailed Fugaw but I didn't return the enclosed registration letter so don't know if they will respond without this.
From reading other forums there appear to be several different programming interfaces to the 320*480 screen ie. sony,garmin palm etc .
Maybe it is something to do with graphics drivers etc.
Cheers,
Paul
paulst
PostPosted: Thu Feb 12, 2004 9:01 am    Post subject: Reply with quote
Mike,
I found this problem mentioned on another forum. If you assign the navigate function to one of the buttons on palm in the Route prefs menu then press this button rather than tapping the onscreen button to navigate it appears to work OK.
Paul
