Pocket GPS World :: View topic - TT6 Map
TT6 Map
asylum
PostPosted: Tue Jan 02, 2007 9:04 pm    Post subject: TT6 Map Reply with quote
I have TT6 runing on my pda for work. I have TT5 running on my mobile phone. My question is will the tt6 map work with tt5.
Asylum
aj2052
PostPosted: Tue Jan 02, 2007 10:22 pm    Post subject: Reply with quote
Version 660 Uk&Ireland plus major roads of WE and Western Europe maps (latest releases) should both work with TTn5,
aj2052
PostPosted: Tue Jan 02, 2007 10:24 pm    Post subject: Reply with quote
answer relevant to PDAs, unfortunately not sure of phones
philpugh
PostPosted: Tue Jan 09, 2007 12:36 pm    Post subject: Reply with quote
I'm not sure that this is correct. Although I am perfectly willing to be proven wrong.
It's down to licensing of the maps enforced on nav suppliers like TomTom by the map 'manufacturers". This is why you need "new" maps when you went from 5.21 to 6. When you come to unlock the TTV6 maps you will need a valid TTV6 product code.
The version of the maps doesn't relate to any particular TT version so both 5.21 and 6 could use the same version of maps but they are different products and are unlocked differently.
Have you tried it yet?
The only reason I asked is when I went from 5.21 to 6 my old 5.21 version of the Canary Isles didn't work. THis was on PDA but the principal applies across the board I believe.
aj2052
PostPosted: Tue Jan 09, 2007 3:32 pm    Post subject: Reply with quote
ttn5 will run v660 maps, but not previous vers 6 maps i.e. 650 or prior, ttn6 will not run v5 maps
DLCPhoto
PostPosted: Thu Jan 11, 2007 2:09 pm    Post subject: Reply with quote
Are you sure about this? The reason I ask is that TomTom has replied to my question on this topic, indicating the opposite. They're saying that TTN6 is required to run the newer Ver. 6 maps.
The context is that I am running TTN5 on my Palm TX. The TX is not on the supported device list for TTN6. I asked them if I could still pay for and upgrade my maps. They said no.
So what's the correct answer here? And if you are able to run Ver 6 maps with TTN5, is there anything special you needed to do in the installation to get things working properly?
Thanks.
philpugh
PostPosted: Thu Jan 11, 2007 5:28 pm    Post subject: Reply with quote
To contradict my previous reply!
TomTom will allow you to upgrade your maps for TT5 to V660 and if you have a supported device (you get to choose from a list) they will give you the upgrade to TT6 also.
The implication is that V660 will run on TT5 and/or 6
aj2052
PostPosted: Thu Jan 11, 2007 7:02 pm    Post subject: Reply with quote
To add to Info, I do believe you need at least TTN5 v5.210(5430) to run v660 maps, check out topic "ever wondered which maps work with your tomtom software" and i quote from one post:
Here's what I've got running for your chart...
App version 5.210 (5430)
GB Map V660
FR Map V660
Benelux Map V566
All work a treat
Unfortunately cannot speak for Palm users because I am on PDA Windows, and now well entrenched with TTN6 and V660 maps and not prepared to backtrak
