Pocket GPS World :: View topic - ONE v1 Speaker troblems....
Hirvevarra
Banned
PostPosted: Thu Jan 04, 2007 2:49 am    Post subject: ONE v1 Speaker troblems.... Reply with quote
May not be the case for everyone but a colleague has a ONE v1 which recently developed 2 troblems:
1. The Speaker packed up but earphone socket still worked ( he occaisionally plugged into van stereo with adaptor ).
2. Poor charging - he often connected charge lead and his ONE battery died while driving along.....
It's out of warranty & I'm a rabid meddler ( & qualified tronix bod ) so......
1. Having popped it open, I found 1 of 2 spring-pins ( which disable the speaker when earphone plug is in ) was oversprung and failing to return to position thus not permitting said speaker to operate.
2. The power connector has a central pin and an outer spring in the housing. The outer spring had...you guessed it....become oversprung and was failing to clasp the power plug & hold it firmly hence poor charging.
These troblems have been rectified & the unit takes / holds charge perfectly and the speaker booms out instructions ( which for a ONE v1 is pretty good ).
If you have a warranty, take it back. If not, it's an easy repair so don't junk it just yet. Let someone qualified take a look and you could get your ONE v1 back better than ever, too !!!!
dpmiller
PostPosted: Thu Jan 04, 2007 10:24 am    Post subject: Reply with quote
...and if you're *really* good, you can sort them out from the outside using a straightened paperclip w/ a tiny hook at the end... :D
PostPosted: Thu Jan 04, 2007 4:04 pm    Post subject: Reply with quote
Beware of shorting outthe battery if you try that on the power socket!
thebinman
Banned
PostPosted: Thu Jan 04, 2007 5:08 pm    Post subject: Re: ONE v1 Speaker troblems.... Reply with quote
Maybe worth adding to the FAQ's methinks?
Hirvevarra
Banned
PostPosted: Thu Jan 04, 2007 8:29 pm    Post subject: Reply with quote
I'd love to see your approach to fixing loose wires in a 3 phase loop connector....... On Fire
*really* good, my a**e!
Go patronise a blond bint with your impressive knowledge of red versus green cars & why it makes one faster!
Ooh, I almost forgot the :D
Andy_P2002 wrote:
Beware of shorting out the battery if you try that on the power socket!
Sensible Advice, Folks...................
Angry Grrrrrrrrrr
23.084 (27 Aug 25)
