Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Thu Jan 29, 2004 9:55 pm Post subject: IPAQ 3970 ROM 2.10 upgrade difficulties
I’m using ActiveSync 3.5 and USB connection to update the ROM from 2.00 to 2.10. The upgrade process has discovered that I’m on ROM 2.00 and I’ve confirmed that I wish to upgrade. I have declined to back up ROM 2.00 as I don’t think there is a need, I don’t want to go back to it.
I’ve got to the point in the upgrade where: -
Follow the instructions below to prepare the iPAQ Pocket PC for the update/restore process:
1. Remove the iPAQ Pocket PC from the USB/Serial cradle/cable.
2. Perform the following steps simultaneously
Press and hold application button #2, and the power button
Whilst holding down these buttons, use the stylus to perform a normal reset.
IPAQ screen goes red with the word “USB” in a white box at the top. The word "Compaq" below that. Finally “v0.48” in a white box at the bottom of the screen. Is this the “update mode”?
3. Reconnect the iPAQ Pocket PC to the USB/Serial cradle/cable.
Click Next to continue. Click Cancel to quit.
I’ve reconnected the iPAQ Pocket PC and absolutely nothing happens. The "Next button" stays greyed out. I’ve rebooted the PC more times than I care to mention. I’m pulling my hair out here. All cables are attached.
I’ve even deactivated ZoneAlarm Pro.
Somebody please help!!!
Thanks,
_________________ Robert.
Garmin Camper 770 LMT-D
Posted: Fri Jan 30, 2004 3:45 pm Post subject:
I'd recommend starting the troubleshooting with removing ithe USB driver for the iPAQ (Compaq ipAQ USB sync) (to allow it to refresh)
then I would install ActiveStink 3.7.1 . (which should also do the trick with refreshing the USB driver)
(and yes, the white/red screen with ****USB*** is the right thingie. The screen will change depending on the connector you use. (Have you tried doing the upgrade via the serial port?) _________________ Lutz
Posted: Sun Feb 01, 2004 8:53 pm Post subject:
Lutz,
Thanks for your reply.
I installed ActiveSync 3.7.1 on my PC (Windows XP Professional) and it didn’t make any difference. However I then decided to use my work’s laptop (Windows 2000) running ActiveSync 3.5 via the USB and the ROM upgrade worked . The only other difference is that I kept the SD card in the iPAQ although I can’t see why this would make a difference to the upgrade process.
I’ve also added the SD Card Driver Update (SP25681) as well.
Posted: Sun Feb 08, 2004 11:57 am Post subject:
I'm glad you finally got the upgrade installed - I believe ROM 2.10 with the SD driver fix is a good choice. I only stopped using it when I installed ROM 4.00.08 (the Pocket PC 2003 upgrade ROM).
There's various reports of people finding that they can't get ROM updates to work. Often ActiveSync 3.7.1 is seemingly the cause. Because of the issues with Microsoft's RAPI changes, I recommend not installing 3.7.1, but staying at 3.7 for now - for more information on this see this thread.
Sometimes these things just don't work properly - though I presume you had followed the advice to make sure that the cradle was connected directly to your PC, and not via a USB hub.
Not backing up ROM 2.00 was a smart move, unless you wanted to check that your setup was working. If you restore a backup of ROM 2.00, it can wipe the asset information, necessitating sending the iPAQ in for repair to get it sorted. If you really want to return to ROM 2.00, there's a 2.00 installer available on the HP web site.
Posted: Sun Feb 08, 2004 5:58 pm Post subject:
David,
Thanks for the additional information, and yes I did follow the advice to make sure that the cradle was connected directly to my PC, and not via my 4 port USB hub.
May I ask your advice on another question or three?
Hopefully I won’t need to perform another Hard Reset on my 3970 for a while, but if I did, would the hard reset remove the SD driver fix?
I can’t remember where the SD driver fix was installed, is there a recommended place for it.
I’m thinking of buying a second 3970 (used from Ebay) for running topographical software (possibly Memory Map 2004). If the 3970 has got ROM 2.10, how can I tell whether it’s got the SD driver fix, and if so what location the SD driver fix was installed in?
Thanks, _________________ Robert.
Posted: Tue Feb 10, 2004 3:29 pm Post subject:
The SD driver fix goes into ROM using the eXecute In Place (XIP) system - it permanently replaces the faulty drivers. You should let it install to main memory - when you soft reset, the XIP file is executed to upgrade the ROM. This means the fix survives a hard reset.
So far as checking as to whether it's installed - I can't think of an easy way. If you have Resco Explorer 2003, you could change the settings to allow you to see files in ROM, then check the time and date of SDBusDriver.dll in \Windows and compare that to your machine that you know you've upgraded. Unfortunately you can't see that and other files in ROM using ActiveSync's Explore feature, nor the built in File Explorer.
The only time you need to reinstall the fix after you have installed it is if you ever reinstall ROM 2.10 - including if you downgrade to Pocket PC 2002 after installing a Pocket PC 2003 upgrade kit. I expect, though, that reinstalling it if it's already installed is benign.
Posted: Tue Feb 10, 2004 9:36 pm Post subject:
David,
Many thanks for your reply. As always, your advice is very useful.
I can’t remember if I used main memory or not on my 3970. I think I used the default setting. Unfortunately I don’t have Resco Explorer, but then I’m not brave enough to start playing with system settings if I did have it.
