Pocket GPS World :: View topic - Fortuna Clip-on GPS
Fortuna Clip-on GPS
alevans
PostPosted: Sat Feb 07, 2004 3:12 pm    Post subject: Fortuna Clip-on GPS Reply with quote
I have an Ipaq and a Fortuna Clip-on GPS which is currently use with TomTom.
Will Mapopolis work with this GPS unit?
The reason I ask is that this GPS uses SiRF rather than NMEA.
Regards
Al
PostPosted: Sat Feb 07, 2004 4:31 pm    Post subject: Reply with quote
The GPS is also NMEA 0183v2 compliant, so it will work.
alevans
PostPosted: Sat Feb 07, 2004 4:37 pm    Post subject: Reply with quote
Well I guess I have a problem!
I have TomTom 2 already installed and works fine.
I have followed the advice about removing TomTom GPS 2.08 so it doesn't hijack the BT.
I have a good fix on my Clip-On.
But when I set up Mapopolis with Port 6 and 38400 baud all I get is "Checking COM6" and then nothing! The Blue LED on the Clip-on flickers as it does with TT2, but seemingly no data available for Mapopolis! I have tried the Auto-detect function as well!
Does anybody have any thoughts?
many thanks
PostPosted: Sat Feb 07, 2004 5:54 pm    Post subject: Reply with quote
Is the GPS running in SiRF or NMEA ? If SiRF, try re-configuring for NMEA as most apps prefer NMEA.
SafeHarbor
PostPosted: Sat Feb 07, 2004 7:10 pm    Post subject: Reply with quote
Actually, Mapopolis will ONLY accept a NMEA stream.
Lamar @ mapopolis support
Mapopolis support
alevans
PostPosted: Sat Feb 07, 2004 11:15 pm    Post subject: Reply with quote
The Clip-on gps is seemingly providing both SiRF and NMEA correctly, as I can select either on TomTom2 and get a fix.
It's just really weird that Mapopolis can't seem see the data.
Reinstalling Mapopolis didn't help either!
Oh well!!!
SafeHarbor
PostPosted: Sun Feb 08, 2004 1:37 am    Post subject: Reply with quote
Hi, again,
Mapopolis has customers using the Clip-On, so are you sure that you're actually setting it for an NMEA stream and using it in the standard mode? (Not the X-mode.) Also, note that you need a specific procedure to switch from one mode to the other, so please reference your documentation.
Lamar @ mapopolis
Mapopolis support
alevans
PostPosted: Sun Feb 08, 2004 4:19 pm    Post subject: Reply with quote
OK good news!!!
I have managed to get it to work!!!
It seems that sometimes regardless of the hardware switch on the Clip-on it starts in XT mode which doesn't have a NMEA data stream.
I have fiddled with it and hey presto.
The correct settings as as per the instruction leaflet COM 6 38400 baud.
Thanks everyone for their help.
jase
PostPosted: Tue Aug 10, 2004 8:49 pm    Post subject: Reply with quote
Hi There
It seems i have the same problem. I recently upgraded to TT GPS 3.03.
On 3.00 it worked but i no longer have the driver for it.
n Mapopolis the bluetooth settings point to com4 however when i try to use com 6 it says GPS Port (Com 6Smile is not available.
I've tried flicking from st to xt and back to st again on my fortuna bt clip on but no joy. It works when i start the drive manually and it works with tom tom.
I'm off to the states in a couple of weeks and need to get it working.
Please help!!!
Cheers in advance
jase
jase
PostPosted: Fri Aug 13, 2004 8:30 am    Post subject: Reply with quote
got it working in the end thanks to lutz.
needed to use the outgoing com port.
jase
