Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Tue Dec 12, 2006 3:01 pm Post subject: |
Stackridge wrote: | Looks like the SP2 patch has been released. Captain Drift has mentioned it on another thread. |
Anyone with any problems sinces downloading it I'm going to wait and see _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
doctorf Lifetime Member
Posted: Tue Dec 12, 2006 3:40 pm Post subject: |
SP2 seems to work fine with no problems!
Simon F |
Posted: Tue Dec 12, 2006 4:06 pm Post subject: |
doctorf wrote: | SP2 seems to work fine with no problems!
Simon F |
Thanks, Doc _________________ Gee-Pee
cook1e Occasional Visitor
Posted: Tue Dec 12, 2006 7:07 pm Post subject: |
cook1e wrote: | Well, I couldn't even load the servbice pack onto my N20
I only tried loading it as I wanted to get the one free camera download you get when you buy a new N20 but the "special offer" link from the ST desktop came up with a message that I needed to download the latest update. When I tried to load the SP1 I got an error message stating that the "language of the service pack didn't match the language of the ST desktop" . I raised a tech support fault with Navman and they advised that there have been some technical problems with camera subscriptions etc that will be resolved in service pack 2 due out next week!
The fact that this is so soon after SP1 shows that thre are some pretty fundamental problems. Don't they test these relases first |
Just tried to load SP2 and got the same error message stating that the laguage of the SP doesn't match ST desktop. Raised another web ticket with Navman.....
Anyone else ever seen the same error? |
imlost Occasional Visitor
Posted: Tue Dec 12, 2006 11:14 pm Post subject: |
seems ok here too, fingers crossed.
Geoff |
darkvisor Occasional Visitor
Posted: Wed Dec 13, 2006 9:01 pm Post subject: |
where are you getting sp2 from, just been on navman site and nothing there only sp1 and in smarST when i try to update, there is nothing there |
Posted: Wed Dec 13, 2006 10:06 pm Post subject: |
darkvisor wrote: | where are you getting sp2 from, just been on navman site and nothing there only sp1 and in smarST when i try to update, there is nothing there |
Same here - have they withdrawn it _________________ Gee-Pee
Posted: Wed Dec 13, 2006 11:58 pm Post subject: |
It's at the same place as SP1 was!!
Simon F |
Posted: Thu Dec 14, 2006 12:02 am Post subject: |
its not there now ??????????????????????? |
Stackridge Occasional Visitor
Posted: Thu Dec 14, 2006 12:51 am Post subject: |
The customer support page mentions SP1 only. Perhaps SP2 was a limited edition !! |
Posted: Thu Dec 14, 2006 8:49 am Post subject: |
When you go to the original update URL download the patcher80.exe and run it; you then have a choice to download SP2. There is no mention of SP2 until you run patcher80.exe
Simon F |
Posted: Thu Dec 14, 2006 9:56 am Post subject: |
Stackridge wrote: | The customer support page mentions SP1 only. Perhaps SP2 was a limited edition !! |
Well, despite me be unable to connect to the Update page last night, when I tried this am I connected successfully. I have now uploaded to SP2 to my N20 and will report back when I have used it.
For information the update (patch) is called SmartST SE SP2 and the file name is setup_4_11_sp2.exe
The effect is to update the SmartST SE from v 4.10.018 to v 4.11.07
The file updates the SmartST SE and then you should reboot your computer. Then open SmartST Desktop and you will be asked if you want to install the update to your Navman. Make sure that you look at the Navman screen after the file appears to have finished loading on your PC as it will still be running on the N20. When the N20 has finished updating, then your should shut down SmartST and disconnect the device.
Posted: Thu Dec 14, 2006 3:00 pm Post subject: |
All default Navman POIs working OK. Have deleted all the old PGPSW POIs and installed yesterdays update Consolidated by type selection. Unfortunately I am back to my old problem in that although the files can be seen via my PC on the card, they do not appear in the list of installed POIs and they do not work. Back to the drawing board. I seem to be the only person having this trouble so what am I doing differently to everyone else Nothing so far as I know....however, I have posted a note on the Speed Camera forum saying that I get a warning after each POI upload saying "XML Doc must have a top level element. Line: 0" whatever that means _________________ Gee-Pee
Posted: Fri Dec 15, 2006 3:28 pm Post subject: |
I happy to report that, at last, my N20 is behaving properly. Had some help from the forum moderator Tim - thanks Tim
I removed all the old installed POIs except the default ones installed by Navman, both from the SD card and the memory.
I then edited each of the downloaded POI files from the 'Consolidated by Type' file by removing the Lat/Long line from each - not strictly necessary because the a; in front of each line makes the POI editor ignore the line. I also removed the 'Control lines' at '0'
I then reloaded all the files to the device memory - not the SD card and all now work.
In addition, I no longer get the warning screen telling me that maps have failed to load.
So one happy bunny
If anyone has a problem loading the POIs let me know if this helps - or PM me and I will talk through. _________________ Gee-Pee
nav-man Occasional Visitor
Posted: Fri Dec 15, 2006 5:57 pm Post subject: SP2 Update |
SP2 update is now out to put right the problems of SP1 but it still rubbish, you can page down once on the alerts screen and see 2 more alerts but that's it, the curser moves down as you page but no more alerts appear.
I have rang Navman and they said they know about the problem and are working on it.
Anybody else tried it out yet? |
