I_Need_Help Regular Visitor
Posted: Tue Dec 05, 2006 12:32 pm Post subject: Anyone got TTN6 working on XDA2i ? |
Thinking of upgrading to TTN6 via download, I know I can just get the maps, but I want to play with new things!!!
so does it work on the XDA2i PPC2003SE???
If I down load TTN6 and don't like it, can I use just the new maps or will I need to pay again for these?
Thanks |
Abb Occasional Visitor
![](modules/Forums/images/avatars/1022282808481499f417356.gif)
Joined: May 19, 2004 Posts: 32 Location: Denbigh North Wales
Posted: Tue Dec 05, 2006 4:46 pm Post subject: TT6 |
TomTom 6 works on my Qtek 2020i, which if you check is the same as the XDA2i. Hope thats some help. |
Posted: Tue Dec 05, 2006 5:18 pm Post subject: |
thanks, what device did you tel them it was when downloading as they won't let you download it if you say XDA2i or Qtec 2020i?
Also is the Qtec running PPC2003?
thanks |
alix776 Pocket GPS Moderator
Posted: Tue Dec 05, 2006 7:25 pm Post subject: |
you should not have any problems with ttn6 and xda2i I think the device selection other than smartphone and ppc will just be for marketing etc just make surw you keep it in turbo mode when running ttn6 alternativly you could just up grade the map of ttn5 _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Tue Dec 05, 2006 7:59 pm Post subject: |
OK thanks
I will give it a go and post back how it goes!!!! |
Posted: Tue Dec 05, 2006 11:17 pm Post subject: |
Well I have paid my money and downloaded TTN6 I selected the MDA as my device, I downloaded TTHome and that installed OK, I backed up the XDA2i (XDAIIi) and selected install all 3 items (TTN6, Map & Postcode) at about 70% of the map it errored, I have ~300Mb free on the SD card but I made another 200Mb free (its a 1Gb card) and loaded just the TTN6 and removed the SD card plugged it back so as the autoplay install ran, then add the map (UK & IE) and then the post code, next came the activation screen I got my product code by double clicking the MAP and activated it.
And Yes it working fine not one issue! postcodes etc all working...
So although TT say Maps only for the XDA2i I say select the MDA and get TTN6 for Free!!!
Thanks |
