Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 75, 76, 77  Next
PaulB2005
PostPosted: Fri Nov 24, 2006 10:32 am    Post subject: Reply with quote
Maybe it will be clearer to explain that one is for the Approach (1st) alert and the other for the Overspeed (2nd) alert.
Mearns
PostPosted: Sat Nov 25, 2006 3:44 pm    Post subject: Reply with quote
Ash10 - thanks for a superb piece of software! Used it with my new Nuvi 660 and it works perfectly. Thumbs Up
Just wish the Nuvi could discriminate between co-located or closely located fixed and mobile cameras by just warning about one of them so I don't get a quadruple "bong"!
Tony
nuvi 2460LT plus Brodit mount
Hammer2006
PostPosted: Sun Nov 26, 2006 7:51 pm    Post subject: Reply with quote
How do you go about uninstalling this application ??? ive got 2 installed by mistake and want to remove one of them.
Ash10
PostPosted: Sun Nov 26, 2006 9:09 pm    Post subject: Reply with quote
If you mean that you've got two copies running in your system tray, just quit them both (using the Quit button in the settings window) - then run the application again (just the once, mind).
Hammer2006
PostPosted: Sun Nov 26, 2006 11:01 pm    Post subject: Reply with quote
I cant get to the settings as left or right clicking with my mouse wont open up the applications, they both just sit there saying camera manager idle Confused
imakora
PostPosted: Wed Nov 29, 2006 2:50 pm    Post subject: Reply with quote
Hi Ash,
Thanks for all the work you've put into the Camera Manager. Is there any way to alter the overspeed warning? I used to get a fairly constant "DING DING", but now have the warning repeating itself approximately every 5 secs. I'm not sure if this is a feature of your utility or not?
Regards, Ian.
Ash10
PostPosted: Wed Nov 29, 2006 4:38 pm    Post subject: Reply with quote
You can disable either/both of the approach and overspeed warnings, by setting the alert time to zero.
What you can't do however, is vary how often the overspeed warning sounds - that's dependant on your particular model of Garmin. On the i2/3/5 this is around once every second, on the Nuvi it seems to be nearer every five seconds or so.
imakora
PostPosted: Thu Nov 30, 2006 6:10 pm    Post subject: Reply with quote
Many thanks Ash.
I've got a Nuvi, and it did give me an overspeed warning every second or so, but this has now changed to every 5 seconds. It must've changed with one of the Garmin updates.
Regards, Ian.
Hammer2006
PostPosted: Fri Dec 01, 2006 4:47 pm    Post subject: Reply with quote
Ash10, still need help please!! cos for the life of me i cant get rid of the bloody thing and ive tried all the normal ways.So any advice what be appreciated Smile
Ash10
PostPosted: Fri Dec 01, 2006 9:36 pm    Post subject: Reply with quote
Check your messages inbox - I sent you a PM last week...
ianandrewhay
PostPosted: Mon Dec 04, 2006 3:26 pm    Post subject: problems... Reply with quote
i have a garmin i2 and am having problems with ash's software. I have windows xp and have downloaded the camera manager but it just says camera manager idle. When i try to load POI's from the garmin folder it says there aren't any in the folder.
i am using software version 3.20
Also a question- when i do load the POIs that the camera manager downloads onto the unit, will it automatically delete or overwrite ones i have loaded on before??
Ash10
PostPosted: Tue Dec 05, 2006 9:57 am    Post subject: Re: problems... Reply with quote
Open the settings window and have a look at what is the latest database version, and the date it was last checked.
ianandrewhay
PostPosted: Tue Dec 05, 2006 10:44 am    Post subject: Reply with quote
Current version: Speed Camera Database Version 4.115 30 Nov 2006
Last Checked: Monday, December 04, 2006 - 11:44:37
Ash10
PostPosted: Tue Dec 05, 2006 11:18 am    Post subject: Reply with quote
In that case, Camera Manager has successfully downloaded the database.
If Camera Manager is idle, and is not reminding you that updates are ready - then it must think that you've already updated your Garmin (it does this whenever you run POI Loader).
Go to the settings window, change one of the timings slightly, then click on the OK button.
You should then start getting reminders to update (as you've effectively changed the database by specifying different timings).
ianandrewhay
PostPosted: Tue Dec 05, 2006 11:40 am    Post subject: Reply with quote
thanks ash. I have now changed the timings, but as yet i have no reminders to update, is this normal?
I have previously manually downloaded a speed camera database onto the unit, do you think this is what is is detecting?
Also do any new updates automatically replace any previous ones?
Page 12 of 77
