Pocket GPS World :: View topic - pin 570 and memory map
vivandphil
PostPosted: Fri Oct 27, 2006 4:20 pm    Post subject: pin 570 and memory map Reply with quote
Hi, I have a pin 570 and have installed memory map software and also installed maps onto separate memory card.
I can not get the pin570 to show the gps location on the memory map software.
I had a Medion pda which I used in a similar way with no problems.
Can anyone advise on the relevant settings to activate the gps??
Thanks.
Mart668
PostPosted: Sun Nov 26, 2006 10:17 pm    Post subject: settings Reply with quote
You need to switch on the GPS port. Unlike Smart ST, the Memory Map software does not switch on the GPS signal when it is started. This nugget is quite well hidden in the instruction book.
Settings - GPS - ON
The orange GPS receiving light should now flash.
You may well get a lock now.
If not, in Memory Map,
GPS - Setup: Manufacturer : None. I think the baud rate will be 9600, and everything else will be greyed out. Should work now.
Good luck
Mart 668
