reefbloke Occasional Visitor
Posted: Thu Nov 16, 2006 4:22 am Post subject: |
You can put an SD card in the 6200 though to expand the mem,that said ive just got rid of mine due to its nav cock ups  |
PUG_306 Occasional Visitor
Posted: Thu Nov 16, 2006 7:43 pm Post subject: Nav_Cam 6200 |
Hi i was just wondering if someone could tell me if you can put different voices on the nav-cam 6200 if so where can i get them from and how do you put these on as ive never had a sat nav before just bought this one from asda, Really hope somebody can help Thanks. |
fd100 Occasional Visitor
Posted: Thu Nov 16, 2006 8:17 pm Post subject: I'm hearing voices? |
I'm hearing voices or rather not....
I mailed the makers about this one when I purchased the nav cam for my step son (read previous post) and sad to say that currently you cannot in fact the only sat nav I know that you can download voices onto is the Tom Tom range (although am sure some one will correct me if I am wrong).
Hope this helps.
FD 8) |
Posted: Thu Nov 16, 2006 8:36 pm Post subject: Re: I'm hearing voices? |
fd100 wrote: | I'm hearing voices or rather not....
Hope this helps.
FD 8) | Thanks for letting me know FD hope somebody finds a way around this problem . |
CompufixUK Occasional Visitor
Posted: Wed Nov 22, 2006 8:47 am Post subject: |
Ive just bought one of these and have discovered some info regarding the voices. Have a look in the "cities" folder on your device, in there you will find a folder marked "English", open it, and then navigate to either male or female. The voice files are all in there. What I did was to open a voice file, i then chose windows media player to play it (not permanently). The player warned me that the file did not have an extension, but it still may be able to play it, which it did.
Now what im going to try is to replace the one of the files with either a wav or mp3 and remove the extension. Then ill see if the gps uses it and accepts it.
Ill post the results here shortly, it could just be a case similar to others where certain phrases are used, such as the tomtom or PB GPS400, which should be easy enough to do |
Posted: Sat Nov 25, 2006 5:19 am Post subject: |
CompufixUK wrote: | Ive just bought one of these and have discovered some info regarding the voices. Have a look in the "cities" folder on your device, in there you will find a folder marked "English", open it, and then navigate to either male or female. The voice files are all in there. What I did was to open a voice file, i then chose windows media player to play it (not permanently). The player warned me that the file did not have an extension, but it still may be able to play it, which it did.
Ill post the results here shortly, it could just be a case similar to others where certain phrases are used, such as the tomtom or PB GPS400, which should be easy enough to do | Ok Mate let us know when you find out. :P |
dantheman111 Occasional Visitor
Posted: Sun Dec 03, 2006 7:45 pm Post subject: |
Just reading this page
Unit is dedicated, Evesham are selling the navcam 7700 instead, which is same hardware but with aa navigator software  |
Posted: Sun Dec 17, 2006 6:27 pm Post subject: |
Having used the 6200 for a while im now thinking of changing it to the AA nav software. The 7700 is an identical unit so it should work. I wonder how much evesham will charge me for a disk? |
theshabbs Occasional Visitor
Posted: Mon Dec 18, 2006 11:19 pm Post subject: |
PM sent m8 for 7700 software. |
Posted: Wed Dec 20, 2006 1:52 am Post subject: |
Where can i get the 7700 software thanks. |
Posted: Wed Dec 20, 2006 5:15 am Post subject: |
theshabbs wrote: | PM sent m8 for 7700 software. | Hi do you know where i can get the 7700 software cheers  |
Anstice Occasional Visitor
Posted: Thu Dec 21, 2006 11:38 pm Post subject: |
Any chance of me getting the same service :D Puuurlease |
skybosun Occasional Visitor
Posted: Sat Dec 23, 2006 11:08 pm Post subject: |
Just got one as a present for son and on testing it seemed to work fine. however, does anyone know if there is a way to delete favourites or other stored points as I cannot seem to find a delete option and the support line is shut for xmas. Do you have to try and go in to the software vica PC to do this. :D |
Posted: Fri Dec 29, 2006 2:37 pm Post subject: |
Anybody know where I can get the 7700 software?  |
wlambert Occasional Visitor
Posted: Fri Jan 05, 2007 4:49 am Post subject: |
Anybody know where I can get the 7700 software for the USA? And How to install it on a 6200? |
