Pocket GPS World :: View topic - automatically connect BT GPS to the PDA?
scope
PostPosted: Thu Nov 16, 2006 10:47 pm    Post subject: automatically connect BT GPS to the PDA? Reply with quote
Is there a way to automatically connect the BT GPS to the PDA when you launch I-go? Currently I have to go to the BT manager and connect it manually.
lbendlin
PostPosted: Mon Nov 20, 2006 6:50 am    Post subject: Reply with quote
If you really want to do that (I can't fathom why) you can use third party programs that first enable BT and then start a specified application.
Lutz
TomTom/TeleAtlas NAVTEQ
scope
PostPosted: Mon Nov 20, 2006 10:20 am    Post subject: Reply with quote
Why? Easy.. It saves when having to connect the GPS every time I get into the car and drive off.. Its would be faster to only press the I-go icon, and off we go - similar to Tomtom navigator.
If I want to use it now I need to press:
"wireless connection" button on front screen
"Bluebooth Manager"
find the GPS and double click
then close the 2 windows I have opened
and THEN I can start i-go
If you know of an easier way then please let me know. Smile
scope
PostPosted: Thu Nov 23, 2006 4:15 pm    Post subject: Reply with quote
Do you have any examples of application that will do this?
lbendlin
PostPosted: Fri Nov 24, 2006 9:19 pm    Post subject: Reply with quote
Here
http://www.pocketnavigation.de/board/tid1031037-sid.htm
Lutz
eva
PostPosted: Mon Dec 18, 2006 1:04 am    Post subject: Reply with quote
If you pair your BT GPS to your PDA. Tap and hold the icon of the BT GPS and select 'connect' (you only need to do this the first time). Start i-go get a connection to the gps with the correct port & baud rate. Then every time you start I-go (whether BT on PDA is on or off it will switch on) & if GPS is on or in stand by, as newer ones have, it connects in a few seconds. The works with both Tom Tom & I-GO.
23.092 (10 Sep 25)
