Pocket GPS World :: View topic - Cleaning the hard drives flash memory?
thebinman
Banned
PostPosted: Fri Nov 17, 2006 5:18 pm    Post subject: Cleaning the hard drives flash memory? Reply with quote
My old One's had so many different map cards in it I think the flash memory on the hard drive (where it stores the activation code from original SD card maps to enable you to then use back-up cards without needing to re-activate each time) is full up.
I've tried "reset factory settings" but this just clears time/settings etc.
Does any expert out there know if there's a way to clean up this flash drive?
Eldar
PostPosted: Fri Nov 17, 2006 8:35 pm    Post subject: Reply with quote
http://www.tomtom.com/updates/ttgo510-710.clear_flash.zip
thebinman
Banned
PostPosted: Sat Nov 18, 2006 11:36 am    Post subject: Reply with quote
Cheers Elder but isn't that the TT clear flash tool that clears too many .mac files off the SD card which then stopped 510/710's continually asking for Activation Codes?
What I think I need is something that stops the hardware writing loads of .mds files to the SD card.
Eldar
PostPosted: Sat Nov 18, 2006 1:11 pm    Post subject: Reply with quote
It will wipe the internal flash memory. The latest firmware versions write the *.mac files both in the internal memory and on the SD card. When you insert a new card, all the *.mac files get copied to the SD card. There are no other tools to clear the internal memory.
thebinman
Banned
PostPosted: Sat Nov 18, 2006 1:29 pm    Post subject: Reply with quote
OK, thanks Elder.
I've normally just run the flash tool on the SD card through a card reader so only cleaned the SD card. Will try it direct on the unit (once I get it back from my mate next week).
Will keep you posted.
Eldar
PostPosted: Sat Nov 18, 2006 1:46 pm    Post subject: Reply with quote
thebinman wrote:
OK, thanks Elder.
As a matter of fact I was wrong - apparently there is another application which runs directly on the unit and not on your PC.
thebinman
Banned
PostPosted: Sat Nov 18, 2006 2:12 pm    Post subject: Reply with quote
Eldar wrote:
thebinman wrote:
OK, thanks Elder.
Where? Where?
Eldar
PostPosted: Sat Nov 18, 2006 2:23 pm    Post subject: Reply with quote
thebinman wrote:
Eldar wrote:
thebinman wrote:
OK, thanks Elder.
Where? Where?
Try the one from TT's website first, if it doesn't work you know where to find me ;-)
thebinman
Banned
PostPosted: Sat Nov 18, 2006 5:57 pm    Post subject: Reply with quote
OK Elder, I'll try it with the SD card in the unit when I get it back next weekend and WILL report back. thanks
thebinman
Banned
PostPosted: Mon Nov 27, 2006 4:20 pm    Post subject: Reply with quote
No joy running the fix even with the SD card in the unit. Still get loads of .mds & .mac files back on once the SD card's reinserted.
Any other ways round this? Plan B?
thebinman
Banned
PostPosted: Thu Nov 30, 2006 11:30 am    Post subject: Reply with quote
Just bringing this back to the top.
Anyone got ANY ideas at all how to clear the hard drives flash memory of .mds & .mac files?
Eldar
PostPosted: Thu Nov 30, 2006 12:50 pm    Post subject: Reply with quote
http://www.satnav-shop.com/index.php?ln=en&pg=6&sec=19
thebinman
Banned
PostPosted: Thu Nov 30, 2006 2:27 pm    Post subject: Reply with quote
cheers Eldar.
Sort of worked in as much as all i got when unit turned on again was white screen.
then deleted the new "system" file, renamed "system.app" back to "system" and reinserted SD card in unit.
Now fires up again OK and only back-loaded 4 .mac files but still back-loade the 21 .mds files!
So maybe just by removing a few (most of) the .mac files it's cleared it. Will let you know.
Eldar
PostPosted: Thu Nov 30, 2006 2:43 pm    Post subject: Reply with quote
try another version http://www.satnav-shop.com/index.php?ln=en&pg=6&sec=19
thebinman
Banned
PostPosted: Thu Nov 30, 2006 3:20 pm    Post subject: Reply with quote
Couldn't d/l this new one. message:
"Sorry - we could not find the file or information you were looking for. Please browse the website from the HOME page. We will take you there in a few seconds or CLICK HERE to return HOME"
