Ben166 Occasional Visitor
Posted: Tue Nov 14, 2006 9:28 pm Post subject: Garmin Nuvi! |
iv just bought a garmin nuvi and i subscribed and downloaded the camera database and uploaded it using the poi uploader but when i use it it keeps giving me very odd speed warnings for example warning me about 42mph on a dual carriage way and showing a little camera on a tripod symbol...what have i done wrong?"!??! |
Scarecrow Lifetime Member
Posted: Tue Nov 14, 2006 10:03 pm Post subject: |
The usual mistake most first time users make is not changing the speed units in POI loader when uploading the database.
As a default POI Loader sets units to metres and kph,. You need to reload the camera database into your Nuvi using POI loader, but make sure you change the measurement units to feet and MPH.
HTH |
heppler Occasional Visitor
Posted: Wed Nov 15, 2006 8:06 pm Post subject: |
I too have just purchased a new Nuvi 300 + TMC. On recept I have seen the 'strange' speeds which do not relate to the actual limit on the road. This is different from the previous Nuvis, I am on mark 3!!, as the previous models showed this correctly. the latest database was installed after the latest release and is different
UI have this afternoon downloaded the POI Loader but which will not link to the Nuvi. As a result I copied the files into the Nuvi having first confirmed that the unit was set to miles and feet.
Two queries 1 How to we get POI Loader activated and do we take it that there is a problem with the settings on the database.
Heppler |
Posted: Wed Nov 15, 2006 8:12 pm Post subject: |
heppler wrote: | I have this afternoon downloaded the POI Loader but which will not link to the Nuvi. As a result I copied the files into the Nuvi having first confirmed that the unit was set to miles and feet. | Where have you plugged the Nuvi in to the PC? the POILoader should work once the device is plugged in but you need to plug it in to a PC USB port, I have had experianced problems if I plug it in via the Hub on my desk or USB ports contained in the keyboard/ Monitor - Mike |
Posted: Wed Nov 15, 2006 8:30 pm Post subject: |
I have plugged the Garmin via the supplied cable directly into one of the Laptop USB ports. Rather than launch the POI loader the Garmin is recongised as an external drive. I have a suspicion the upload was incorrectly done prior to my purchase and now need to rectify the error.
Heppler |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Nov 17, 2006 10:56 am Post subject: |
Once the drive has been recognised by Windows, then start POI Loader, which will hopefully spot this drive as the method of accessing the Nuvi.
If you follow this, what happens when you start up POI Loader? |
rouse Occasional Visitor
Posted: Sat Nov 18, 2006 4:08 am Post subject: How does the speed camera pois work |
Ive downloaded the speed camera POIs to my Nuvi 300 using Garmin POI loader... no problem there. Spotted the new icon in the Nuvi.... and wondering if there is anything else I need to do? or will this just start shouting at me when its approaching a speed camera? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Sat Nov 18, 2006 1:05 pm Post subject: |
i'm going to add a sticky for this titled 19mph warnings...
MaFt |
Posted: Sun Nov 19, 2006 1:43 pm Post subject: |
I tried a variety of solutions and eventually deleted all the informatiion from the laptop. I tried installuing agin and the POI loager now seems to work. I have updated the Nuvi 300 this morning and will try this on a trip I have tomorrow. If this has worked I'll post a note tomorrow night.
heppler |
