Pocket GPS World :: View topic - Using Ferry Lines
Using Ferry Lines
Goto page Previous  1, 2
Skippy
PostPosted: Tue Nov 14, 2006 7:56 pm    Post subject: Re: How to force it to use the channel tunnel Reply with quote
KayMBee wrote:
This is how to force it to use the channel tunnel. Can you do something similar with the ferries?
You can't navigate using GPS in the tunnel so why bother setting a via point actually IN the tunnel. Confused Route to the channel tunnel entrance point and when you get to the other side of the crossing, program it to route to your destination.
Gone fishing!
swing
PostPosted: Tue Nov 14, 2006 8:04 pm    Post subject: Reply with quote
By setting a VIA in the middle of the tunnel the unit will go via the tunnel for the actual route, and provide an ETA for the whole journey.
Skippy
PostPosted: Tue Nov 14, 2006 10:14 pm    Post subject: Reply with quote
Not an accurate one though - according to Mapsource, the crossing will take 2.5 hours - it is marked as a ferry crossing (on the v7 maps anyway). 8O In addition to that, it doesn't know how long you will be waiting for the train.
OK, it will provide a distance, but that isn't really relevant either because you won't be driving that distance.
What I do when I get to the tunnel entrance is set the location on the Garmin to Calais and get it to calculate to my destination. It will then give a travel time for when I emerge from the tunnel/ferry. Sorted.
Each to their own though! It gives us something to tinker with during the somewhat boring train trip. Smile
Gone fishing!
AlanDB
PostPosted: Wed Nov 15, 2006 9:43 pm    Post subject: Reply with quote
Thanks KMbee for pointers and suggestion. Will try next time but am sure it will work given your experience.
The reason for doing this Skippy is as Swing says - it gives a reasonable approximation to eta and distance, and even if the tunnel transit/waiting time is not accurate it is no worse than the estimates based on ferry crossings which the Nuvi otherwise uses.
The version 8 maps show the channel tunnel crossing as a rail link not ferry link.
Page 2 of 2
