silverfoxcc Occasional Visitor
Posted: Thu Nov 09, 2006 6:23 pm Post subject: TT5 Postcode search |
I have just 'upgraded' my TT5 to full Pcode search.
I thought that it would ask me the no of house after the input of the postcode, but it seems it is still in old mode, by showing the list of code of just the first 4 input lettere/figures as before
Have i missed something, or am i looking at the kings new clothes? |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Thu Nov 09, 2006 7:33 pm Post subject: |
First of all are you entering the postcode in the correct area, go to Navigate To/ NEXT PAGE and select Postcode, it is only this area that allows you to input full postcodes. _ Mike |
Posted: Fri Nov 10, 2006 1:59 am Post subject: |
Yes, I went to the Postcode icon and it has (on my Dell Axim)
Postcode at top (with flashing cursor, the next section down shows previuos addresses with up/down arrows at RHS
then there is the numeral section (two rows 1-5 and 6-0 underneaththe the letters in Alphabetical order
I input the code and the address part then shows the part postcode
eg i input pe38jd and i get
pe38 0 (downham....
pe38 9 (Downham...
pe3 6(peterborou...
pe3 7 (peterborou...
I thought that it would ask me the house num,ber after inputting pe38jd.or am i expecting too much?
Will put another request on as my PC (XP) wont or cant open this file
pocketgps_uk_sc.ov2 which is 357kb |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Fri Nov 10, 2006 8:51 am Post subject: |
I don't know how you 'upgraded' to the Postcodes, but did you also put a Folder named TomTom in the Root of the SD Card. It can be empty. _________________ Richard
Posted: Fri Nov 10, 2006 2:38 pm Post subject: |
Went to Tomtom site and followed the instructions re the postcode search query in the FAQ
Have i not done something then? |
derek500 Occasional Visitor
Posted: Fri Nov 10, 2006 3:52 pm Post subject: |
Have you got the 'zip' folder containing the 'Great_Britain.postal' and Great_BritainPostal.ver' files on your memory card? |
wiz Regular Visitor
![](modules/Forums/images/avatars/113930636546c977eb3500f.jpg)
Joined: Aug 08, 2005 Posts: 241 Location: Dartford, Kent, UK
Posted: Sat Nov 11, 2006 1:20 am Post subject: |
Hello Guys :D I have a problem with post codes.
Have ttn5 5.210 (5431) hp2110 pda can find a zip file any where?
just re installed from tt web site still no zip file any suggestions????? |
wiz Regular Visitor
Posted: Sat Nov 11, 2006 1:21 am Post subject: |
cant find a zip file |
Posted: Sat Nov 11, 2006 6:37 am Post subject: |
wiz wrote: | cant find a zip file | Its not a zip file it is a Folder in the root of the SD card named zip, your postcode file resides within it. Pop in your map CD and under the option to install maps is a check box to install Postcode (easy missed), select this and the relevant file will transfer to your device - Mike |
wiz Regular Visitor
Posted: Sat Nov 11, 2006 12:30 pm Post subject: |
Thanks Mike :D
Will give it a go.
Haven’t need full post code before, when i needed it, it wasn’t there oh hum. ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
wiz Regular Visitor
Posted: Sat Nov 11, 2006 10:02 pm Post subject: |
Hi Mike
Installed from TT disc and works a treat thanks, I can see now how I missed it on first install
Wiz (Alan):D |
Posted: Sat Nov 11, 2006 11:24 pm Post subject: |
On my CF card on the dell i have a folder
Greatr Britain map that when i open has 12 other files in it
The other folder is just named zip and when i right click and open this it has a file great britain postal of 8.47mb
Is there anything else i need or can do, this is driving me nuts!! along with the non download of the camera base!! (see post in the download forum)
There must be something better to do on a Sat night
someone assist me to keep what hair i have
Ron |
Posted: Sun Nov 12, 2006 12:21 am Post subject: |
silverfoxcc wrote: | Is there anything else i need or can do, | Do you have an empty Folder called Tomtom at the same level as the Zip Folder? _________________ Richard
