buddybuddy63 Occasional Visitor
Posted: Fri Nov 03, 2006 2:39 pm Post subject: TT5 says, "you did not select a useable voice!" |
I've just installed TT5 on my Mio P350. I preferred to install by loading the appropriate folders onto my SD card rather than using sync via PC. Everything seems to work apart from voice, I get a message which says "you did not select a useable voice!" when I try turn sound.
When I try to change voice I get a choice of Richard, Jane, Tim, Lori or Bonnie - but I get the same message whenever I try selecting any one of them..javascript:emoticon('')
Sad
I have downloaded all the free zipped voice files available on the TomTom website but I don't know where they need to go on my SD card. I seek your wisdom and guidance javascript:emoticon('')
Rolling Eyes
Cheers |
Posted: Fri Nov 03, 2006 3:29 pm Post subject: |
Create a folder in the root of the SD card (thats the top level) call it voices you put the voice files in this folder, you will also need to create a folder called TomTom in the root of the SD card don't put anything in here but it needs to be present - now your voices should select |
Posted: Fri Nov 03, 2006 5:15 pm Post subject: |
mikealder - I did exactly what you said (ie: created new voices folder in root directory on SD Card and put unzipped downloaded voices folders into it; also created empty TomTom directory) but I still get the "you did not select a useable voice!" but this time it flashes twice before going away
In case this may help explain why I get this problem, I have the following folders in root directory on my SD Card:
Great_Britain_Plus-Map (out of CD2)
Great_Britain-Map (out of CD2)
Licences (out of CD1 I think)
manual (out of CD1)
nvapp (out of CD1 I think)
pocketpc (out of CD1 I think)
rsc (out of CD1 I think)
TomTom (empty as advised)
voice (out of CD1)
voices (with voice folders such as "Bonnie", "Jane", "Ken" etc...)
zip (out of CD2) |
Posted: Fri Nov 03, 2006 5:37 pm Post subject: |
buddybuddy63 wrote: | voices (with voice folders such as "Bonnie", "Jane", "Ken" etc...) | I had to read this post a few times until the obvious hit me, you have put the voices in sub-folders, this is not correct, the voice files will be data05.chk and data05.vif (only the numbers change to denote which voice they are for, simply put each dataXX.chk AND associated dataXX.vif file straight into the voices folder - DO NOT USE SUB FOLDERS, when you have moved the files delete the subfolders - Mike |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Nov 03, 2006 6:24 pm Post subject: |
On my P350 I have the following folders on the SD Card.
Great_Britain-Map
France_Plus-Map
New Folder containing the following .CAB files
(engf, engm, GPS, PIMAddIN, TTN, WZD)
TomTom (empty but needed for Full Postcode to Work)
ZIP (containing postcode data)
and
ignore_my_docs. (A hidden file)
I have set all .CAB files to Read Only so in the event of a flat battery I can re-install TT.
I did try the Voices folder but there appeared to be a slight lag in use. Tapping on the engf.cab (Jane's voice) puts her on the PDA. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Fri Nov 03, 2006 8:05 pm Post subject: |
mikealder - well spotted, I think voices on my TT5 set up now works, thanks for your help.
I am wondering if I need all those other folders not specified by the earlier posting by Lost_Property such as:
- Great_Britain_Plus-Map (don't see difference between this and Great_Britain-Map other than extra options by subscription which I wouldn't use)
- Licences
- manual (this for sure can go)
- nvapp (what does this do?)
- pocketpc (this has tomtom and ttn CAB and INI files, should these be made read only?)
- rsc (contains loads of bitmaps and text files, 1 WAV and one INI file)
- voice (contains loads of CABs, WAVS and INIs) |
Oldboy Pocket GPS Moderator
Posted: Fri Nov 03, 2006 8:12 pm Post subject: |
buddybuddy63 wrote: | - Great_Britain_Plus-Map (don't see difference between this and Great_Britain-Map other than extra options by subscription which I wouldn't use) | The Plus-Map is only a Country Specific Map PLUS the Major Roads of Europe intergrated.
It has nothing to do with the Plus Services that TomTom provide.;) _________________ Richard
Posted: Fri Nov 03, 2006 10:21 pm Post subject: |
buddybuddy63. You only need the ones I mentioned above.
Make sure the .cab files are read only, otherwise if you re-install TT by using them they will disappear after one use
You only need one PLUS map. I chose the French plus map so that when I travel to France I choose the France plus map, set my destination and am guided over the major roads of Europe through GB and on arrival in France I have Street level without having to change maps.
By the way, the New Folder I mentioned is one I added to put the .cab files in. In the event of a flat battery you can connect to a mains adapter or car charger and using File Explorer browse to the folder on the SD Card, tap on each .cab file, one at a time, to install TT. _________________ Formerly known as Lost_Property
Posted: Sun Nov 05, 2006 9:57 pm Post subject: |
Lost_Property, Oldboy many thanks for your help 8) |
