gadget_sa Frequent Visitor
![](modules/Forums/images/avatars/28214692144d877d7ede33.jpg)
Joined: Dec 02, 2005 Posts: 334 Location: Wiltshire, UK
Posted: Sun Oct 29, 2006 6:03 pm Post subject: |
Cheers korndog, yes, makes sense now.... _________________ Steve
iPhone 6 with Western Europe & CamerAlert |
scoopjeff Occasional Visitor
![](modules/Forums/images/avatars/1914747476454a7c430c032.jpg)
Joined: May 12, 2006 Posts: 38 Location: Northumberland, next to chip shop
Posted: Sun Oct 29, 2006 7:48 pm Post subject: |
korndog wrote: | I think he means put 2 warnings on the sound file but with a 30 second gap. I would have thought that would make the file too big for TomTom to handle |
Cheers Korndog, thats exactly what i meant. Not good at explaining things sorry guys and gals. As for the file being to big my tomtom 910 has no problems at all with them. I can upload the full set I use if anyone wants them, just PM me or answer to this post.
Kind Regards
Scoop |
Mullet Frequent Visitor
![](modules/Forums/images/avatars/1800373384d166f83c2aac.gif)
Posted: Sun Oct 29, 2006 8:03 pm Post subject: |
What happens if there is a directional instruction while this lengthy file is running? Surely one will conflict with / cancel with the other. |
Posted: Mon Oct 30, 2006 12:48 am Post subject: |
Not had that problem yet in my neck of the woods. I can see what your meaning though
regards
scoop |
Posted: Mon Oct 30, 2006 10:06 am Post subject: |
I only have the RedLight warning using the ogg file format on my 910 (all the rest use TTS), what the device does, and this applys to BOTH ogg and TTS. If it is playing a POI Warning and needs to issue a navigation prompt the navigation voice takes preference. Mike |
Nolongerlost Regular Visitor
![](modules/Forums/images/avatars/gallery/familyguy12.jpg)
Joined: May 07, 2006 Posts: 78 Location: Sherwood Forest
Posted: Tue Oct 31, 2006 12:21 pm Post subject: Original data.chk file |
I'm sure I should know the answer to this, but where can I get a copy of the original TomTom data.chk file (with all the bells, whistles, etc) that will work with my version 6 software on my 10 series Go, as I intend to try to use this new method of Speed Cam warning voices?
The original data.chk file I have saved to my HDD will not work with my unit, as I have updated the TomTom software several times in the interim (via TomTom Home) since using the PocketGPS POI warnings data.chk file. _________________ TomTom 720
App 9.465.1074274.1 OS:842337
GPS v1.20 Boot 5.5120
Maps: Western_Europe v905.4754 |
Posted: Tue Oct 31, 2006 1:04 pm Post subject: |
If you re-install the latest TomTom software via home this should recreate/ load the unmodified data.chk file - Mike |
ttrevor Lifetime Member
![](modules/Forums/images/avatars/gallery/1_block2_satellite.jpg)
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Tue Oct 31, 2006 6:38 pm Post subject: |
Does any one know if there is a set of the pwgps ogg files without the alarm at the begining ,or a more softer tone type alarm as the present one nearly makes me jump out of the car 8O . help much appreciated _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
Posted: Tue Oct 31, 2006 7:00 pm Post subject: |
Just go to www.tomtomsatnav.info/realvoice.html and download the .ogg files (they are at the bottom of the page). You will need to re-name each file to corespond to the POI file names (they must match exactly) - once this is done place the ogg files into your map folder and re-configure your warnings - (I use the Liz voice at 22050Hz for the PDA/ PNA device) - Mike |
Posted: Tue Oct 31, 2006 7:33 pm Post subject: |
Thanks Mike will have alook ![Thumbs Up](modules/Forums/images/smiles/custom2.gif) _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
Posted: Wed Nov 01, 2006 9:57 am Post subject: |
[quote="mikealder"] mikealder wrote: |
For those using the Speed Zoned file type download:
pocketgps_uk_gatso_20.ogg
pocketgps_uk_gatso_30.ogg
pocketgps_uk_gatso_40.ogg
pocketgps_uk_gatso_50.ogg
pocketgps_uk_gatso_60.ogg
pocketgps_uk_gatso_70.ogg
pocketgps_uk_gatso_tba.ogg
pocketgps_uk_gatso_var.ogg
pocketgps_uk_mobile_20.ogg
pocketgps_uk_mobile_30.ogg
pocketgps_uk_mobile_40.ogg
pocketgps_uk_mobile_50.ogg
pocketgps_uk_mobile_60.ogg
pocketgps_uk_mobile_70.ogg
pocketgps_uk_moblie_tba.ogg
pocketgps_uk_specs_20.ogg
pocketgps_uk_specs_30.ogg
pocketgps_uk_specs_40.ogg
pocketgps_uk_specs_50.ogg
pocketgps_uk_specs_60.ogg
pocketgps_uk_specs_70.ogg
pocketgps_uk_specs_tba.ogg
pocketgps_uk_redlight.ogg
pocketgps_uk_temp.ogg
Mike
I've also got a pocketgps_uk_mobile_var from the latest camera download, which does not seem to be in your list and does not seem to have an.ogg file in the zip file I have obtained.
Any reason for this?
Successfully updated my 510 with TomTom Home and obtained an original data.chk file, just as you suggested, so many thanks for that. _________________ TomTom 720
Posted: Wed Nov 01, 2006 10:00 am Post subject: |
There is a reason that the mobile var file is in your folder, Mike B mentioned something about this being an error that the database throws out, I would delete it if I were you - Mike |
operasinger Lifetime Member
![](modules/Forums/images/avatars/gallery/1_tomtom_one.jpg)
Posted: Wed Nov 01, 2006 2:17 pm Post subject: |
mikealder wrote: | Are you 100% sure that both the .ogg files are named correctly AND you have re-configured the warnings for ALL the cameras you have installed?
View the ogg files in Windows Explorer and make sure non have a double file type extension i.e. they should end .ogg NOT .ogg.ogg (a few people have had this problem so far), - to view the file extensions in Windows Explorer go to Tools/ Options, select the view tab then make sure the check box for "Hide extensions for known file types" is NOT checked.
The only other thought is you could have more than one set of camera POI's installed to the device, assuming you have the Speed Zoned set installed there should only be 24 .ov2 files that start with the pocketgps name, if there are more than this the POI warner could be picking up the extra files and not the ones you think you have configured - Mike |
Mike many thanks for helpful suggestions.
I have checked all your advised changes.
I have now Deselected ALL Poi prompts, shut down and re-selected all catagories once again with .ogg's in place and old data.chk.
Seems to be working.
Deselection was the key.
Another satisfied customer |
adventurer Regular Visitor
Joined: Jul 08, 2004 Posts: 83 Location: Midlands, UK
Posted: Wed Nov 01, 2006 4:17 pm Post subject: |
Im using Navigator 5 using a T mobile MDA Vario.
Followed all you helpful information and comments and have got it all to work fine. At first I was having a problem, I typed in gasto instead of gatso
Anyway, because I used to use checkpoint and I am used to the seconds setting before the camera. I am finding it a bit hard to judge the correct distance in yards that I should use on the tom tom system.
Has anyone got tried and tested distance settings for the entire database please?
Thanks _________________ Tom Tom One Series 30 with TMC
Brodit Mount permanent mount
GlobalSat Bluetooth GPS - BT 338
Now IPhone 4 with Tom Tom |
Posted: Wed Nov 01, 2006 4:26 pm Post subject: |
I am sorry if this off topic, but I have set the 30 gatso at 300yds and then i decided to change it to 250yds. I did a route demo in between these changes and then when I went to change it to 250 I noticed that the 300yds I had sent had on it's own changed to 299yds.
Should this happen, how do I stop it from happening?
If I can't stop this everytime I go past a camera the distance will reduce and I will have to re-set all the distanced every month.
help please................. ![Question](modules/Forums/images/smiles/icon_question.gif) _________________ Tom Tom One Series 30 with TMC
