djc1610 Regular Visitor
Joined: Nov 18, 2005 Posts: 186 Location: St Neots, UK
Posted: Wed Oct 25, 2006 10:20 pm Post subject: Searching |
I am interested in finding a way of getting a full post code search on T5.
So I enter in the search box "Tomtom full post" and get 28003 posts (how many?????)
So I now enter "Tomtom full postcode" and get 30971.
99.99% of these posts have nothing to do with what i am searching for.
Can anyone please tell me what is the point of doing a search with more than one word in the box?[/code] |
Posted: Wed Oct 25, 2006 10:30 pm Post subject: |
Assuming the zip folder on your memory card contains a Great Britain Postal file then you should be OK, If not use the CD to install the post code as it is an option when installing maps.
Next, do you have a folder called tomtom on the memory card, if not create one, it doesn't need anything in it, but its presence makes it work.
If both of the above are already in place are you selecting the postcode method correctly? - you can only use 5 digit postcode when entering an address, use the Navigate to and select the next screen (bottom Right icon), then select postcode, this icon gives full access to the 7 digit postcodes - Mike
Edit once mikealder, to correct typos (thanks LP)
nivek22 Lifetime Member
Joined: Mar 09, 2006 Posts: 194 Location: Barnsley, South Yorkshire.
Posted: Wed Oct 25, 2006 10:33 pm Post subject: |
Select "Search for all terms" under your "keywords". |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Wed Oct 25, 2006 11:53 pm Post subject: |
Quote: | but its presence makes it work |
Naughty naughty, Mike Alder. :P _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Wed Oct 25, 2006 11:54 pm Post subject: |
Quote: | If both of the above are allready in place |
You're getting worse!! :P _________________ Formerly known as Lost_Property
Posted: Thu Oct 26, 2006 6:29 am Post subject: |
Cheers for the heads up, new batteries are now installed in the keyboard, hope it doesn't do it again Cheers - Mike |
