Pocket GPS World :: View topic - TomTom Navigator 1 and O2 XDA2?
clinton
PostPosted: Mon Jan 19, 2004 12:46 pm    Post subject: TomTom Navigator 1 and O2 XDA2? Reply with quote
HI,
I am about to purchase an O2 XDA2, but first want to make sure it supports TomTom Navigator 1 ?
Thanks!
PostPosted: Mon Jan 19, 2004 3:32 pm    Post subject: Reply with quote
The XDA II supports TomTom 1 as a program. Your problem will more be in the kind of GPS receiver you are planning to use. TomTom 1 was conceived before the broad acceptance of BlueTooth receivers., and the BT COM port may not be visible in the TomTom GPS applet.
clinton
PostPosted: Mon Jan 19, 2004 4:58 pm    Post subject: ? Reply with quote
Thanks for the help!
I was using my bluetooth globalsat GPS with TomTom 1 on my iPaq 3970, but now want to upgrade to an XDA2 but with using the same software and GPS.
Is it then okay?
Clinton
PostPosted: Mon Jan 19, 2004 5:08 pm    Post subject: Reply with quote
Should be ok then. Just make sure you install the BT patch for the XDA II.
DavidW
PostPosted: Mon Jan 19, 2004 10:07 pm    Post subject: Reply with quote
I'd be concerned about using TomTom Navigator 1 on the XDA II - because the XDA II is a Pocket PC 2003 machine and Navigator 1 isn't officially Pocket PC 2003 compatible. Someone that tried Navigator 1 on a Pocket PC 2003 machine (I think it was an upgraded Dell Axim X5) appeared to hit trouble - though he hadn't got the latest 1.53 version (it seems that the 1.53 upgrade is no longer available from the TomTom site). I can't find the forum thread on this.
GPS wise, if you install GPS 2.09 (which I normally don't recommend, but I would in the case of an XDA II) it should install the necessary support for a Bluetooth GPS. I believe that's the whole point of the Bluetooth DLLs in the TomTom Wizard component that I'm usually so unhappy about. I don't think you need the unofficial patch in this case.
22.062 (12 Jun 24)
