iancjc Frequent Visitor
![](modules/Forums/images/avatars/avatar_sp_034.jpg)
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Wed Oct 11, 2006 1:36 am Post subject: |
is the tmc data any different from the gprs data?
I've been using traffic for the past 18 months and finally the gprs data is reliable and mostly upto date - does gprs use the same data -
I' m not sure I'd be happy about the regional data on tmc though, I often do a 220 mile drive upto Lancashire and have the choice of A1 M62 or A14 M6 M62 (only about 10 miles in it either way) and would be gutted not to get details of problems further into my journey as that would completely change my route... _________________ -----------------------------------------------------------
TyTn II (WM6.1) / tomtom one v2
TTN6.03 tomtom 7.xx (one) |
mwfox Regular Visitor
Joined: Jun 18, 2006 Posts: 149 Location: Buckingham. UK
Posted: Wed Oct 11, 2006 10:06 am Post subject: |
I think the GPRS data will be the same as the TMC data - both from Itis.
Can someone else confirm if they only get regional traffic information as well - I would have thought the same data would have been broadcast nationally. |
etlsngd Occasional Visitor
Posted: Wed Oct 11, 2006 11:27 am Post subject: |
iancjc wrote: | is the tmc data any different from the gprs data?
I' m not sure I'd be happy about the regional data on tmc though, I often do a 220 mile drive upto Lancashire and have the choice of A1 M62 or A14 M6 M62 (only about 10 miles in it either way) and would be gutted not to get details of problems further into my journey as that would completely change my route... |
I asked the same question to Tomtom and they replied by pointing me to the following:
http://www.tomtom.com/page.php?Page=rds-tmc
Doesn't completely answer the question, I interpret it as the 2 offer basically the same information w.r.t traffic from itis, by tomtom refer the their plus service as more "accurate" and "high performance" although when you look at the details. I think this means that you can get extra info like wetaher and read condition, which is pretty useless really as I find the best way of checking weather and road conditions is to look out of the window....clearly they are lookig at differentiating their service to justify ongoing yearly subscription..
/Steve |
duckie008 Regular Visitor
Posted: Wed Oct 11, 2006 1:29 pm Post subject: |
i've started a new thread under "RDS-TMC Traffic or TomTom Traffic" (in the UK) for your opinions on both services as this thread was originally about the receiver being available in Europe, etc |
coastersteve Regular Visitor
Joined: 06/05/2003 18:01:04 Posts: 83 Location: United Kingdom
Posted: Wed Oct 11, 2006 2:25 pm Post subject: |
I've just had mine arrive from Easy devices, just need the 910 back from TT because it wouldn't charge ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Wed Oct 11, 2006 4:51 pm Post subject: |
Do people get disconnections from the TMC receiver when the mount disconnects on the x10 series? (I didn't think the new mount cured this problem - the software update hid the problem). |
jamiepyoung Regular Visitor
Posted: Wed Oct 11, 2006 8:05 pm Post subject: |
OK, second day of trying: over the space of an hour it tuned in to various stations (never classic), but i got no traffic info.
help!!
(i've still got the old mount - could it be that?)
jamiepyoung wrote: | ok, what am i doing wrong???
plugged the new tmc receiver in, its recognised etc.
selected uk
it eventually found radio 2 and 3, but lost these after a while.
in a 1 hour journey, i got no info.
i had the aerial stretched out (about 75% of it).
help..... |
lydiachris Regular Visitor
Posted: Wed Oct 11, 2006 10:14 pm Post subject: |
Nothing to do with the mount.
just MAKE SURE you have straightened out the cable as much as possible and selected, under tmc country, "Strongest Signal" I've found this is much more reliable and tends to lock onto radio 4 and classic fm quite a lot.
I've found when you select "United Kingdom" it seems to hunt down the local stations first then if that fails, it will lock onto the regional ones.
This is what your experiencing with the dropping out of the signal. Hope this helps.
lydiachris |
TonyHoyle Regular Visitor
Posted: Thu Oct 12, 2006 1:22 am Post subject: |
If it's locking into Radio 4 it is not working. Radio 4 does not broadcast TMC.
Seems to be a common fault with this device... TT are going to have to do an update quick or get a lot of returns I suspect. |
Posted: Thu Oct 12, 2006 10:06 am Post subject: |
yay!
it worked this morning - put it on strongest signal as recommended above and eventually picked up classic.
it didn't pick up any delays on my route, so i thought it wasn't working (i travel M40 - M42 - M5 - M6 - M54 every day to work) - but, it was only only flipping correct! a clear run for the first time in weeks!
it did pick up delays on the other carriageway, so it was working.
the only negative, it took about 20 minutes to find classic and get reports - given that this was the first time it has found it, will it be quicker next time (now that it knows the frequency)?? |
Posted: Thu Oct 12, 2006 4:00 pm Post subject: |
Tomtom say
"The TMC receiver gives traffic information for the whole UK at one time"
So does not divide the info into regions. |
Posted: Thu Oct 12, 2006 4:53 pm Post subject: |
Well thats a load of rubbish.
When in the norfolk area, I can get traffic info ONLY for roughly a 150 mile radius.
Can someone else with the tmc receiver, go to "traffic" then "Browse Map" then zoom out and see how far their red dots expand to when hooked to classic FM.
Another question of mine, when radio eventually becomes digital, will our tmc receivers stop working??!! 8O |
Posted: Thu Oct 12, 2006 4:57 pm Post subject: |
lydiachris, how long does yours take now to start colleccting traffic info from start up? |
Posted: Thu Oct 12, 2006 5:02 pm Post subject: |
About a minute why??!! |
