Pocket GPS World :: View topic - Poorly TT500
Poorly TT500
tr7v8
PostPosted: Tue Oct 03, 2006 9:14 pm    Post subject: Poorly TT500 Reply with quote
Wife's 500 won't power on unless connected t either the car power or its mains charger. Tried hard reset & it still won't play. Anyone got any ideas?
Jim
Tumbleweed
PostPosted: Tue Oct 03, 2006 11:15 pm    Post subject: Re: Poorly TT500 Reply with quote
Jim
have you left it to charge overnight?
tw
thebinman
Banned
PostPosted: Wed Oct 04, 2006 9:28 am    Post subject: Reply with quote
Battery or IC knackered.
PostPosted: Wed Oct 04, 2006 1:06 pm    Post subject: Reply with quote
Suggest you try http://www.satnav-shop.com/index.php?ln=en&pg=2
Eldar
PostPosted: Thu Oct 05, 2006 2:58 pm    Post subject: Reply with quote
Probably the IC if it doesn't start at all on the battery.
tr7v8
PostPosted: Thu Oct 05, 2006 5:54 pm    Post subject: Reply with quote
Thanks guys, err what's the IC?
Eldar
PostPosted: Thu Oct 05, 2006 6:11 pm    Post subject: Reply with quote
It's an Integrated Circuit (IC) which supplies 3.8V to the internal circuitry and the battery charger IC :-). For whatever reason the 3/5/700 series is suffering from this fault - half of the IC blows up, but the other half is functioning, so that you can switch the unit on and use on external power, but the blown part of this IC creates a short circuit and prevents the battery from charging properly. In fact your unit is (probably) constantly drawing up to 1.5 Amps from any power supply you connect it to.
thebinman
Banned
PostPosted: Thu Oct 05, 2006 7:21 pm    Post subject: Reply with quote
Will cost you around £65ish to replace the IC & battery.
I know. Been there; done that!
tr7v8
PostPosted: Thu Oct 05, 2006 11:05 pm    Post subject: Reply with quote
Hopefully this will be under the 2 year warranty, because it's only 15 months old.
22.055 (29 May 24)
