benmarsh Occasional Visitor
Posted: Wed Oct 04, 2006 2:58 pm Post subject: TomTom One v2 power connector |
I'm hoping someone with a v2 can help me with this question:
Looking through the pictures of the new v2 I notice it uses a mini USB to power and charge the unit. It seems that it is a flat/straight usb connector rather than an L shaped on which I currently have on my Garmin i3. As the power socket on the unit is at the bottom it would seem that I won't be able to mount the TT low on my windscreen close to the dash in the same way as I can with the i3.
Secondly how long is the supplied USB connector? I have a new model Clio which has the 12v socket between the handbrake and the drivers seat and I tend to position the gps on the right hand side of the steering wheel about an inch or two above the dash - so it would need to stretch quite a way.
Thanks,
Ben |
Griff Occasional Visitor
Joined: May 14, 2004 Posts: 57 Location: Northolt, Middlesex
Posted: Wed Oct 04, 2006 4:49 pm Post subject: |
bought my v2 last week and it has a bent connection it has a fairly long lead but not sure how long you need it i will measure it for you if you want
Griff |
timber Frequent Visitor
Joined: Jan 18, 2006 Posts: 422 Location: Wild and Windy SW Scotland UK
Posted: Wed Oct 04, 2006 5:08 pm Post subject: Re: TomTom One v2 power connector |
benmarsh wrote: | Hi,
Thanks,
Ben |
Total length is 64" 1.625 mt (total length including 12 volt connector) usb connection is L shaped but fits directly below and not at an angle you can of course buy a right angled connector on ebay for a couple of ££'s if you want to reduce the height. |
Robin2 Lifetime Member
Posted: Wed Oct 04, 2006 6:36 pm Post subject: |
Yes, it is a right angled connector, but you can't get the TomTom closer than about 1 inch from the dash.
The length of the wire (excluding the connectors on the ends) is 1.5 metres - more than enough to have the GPS on the extreme RH corner of the screen and plug into the cigar lighter low down on the centre console. I have to coil up the surplus cable
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
