Pocket GPS World :: View topic - Warning Tomtom on Orange SPV M600
Goto page Previous  1, 2, 3, 4  Next
Noony
PostPosted: Tue Sep 26, 2006 3:40 pm    Post subject: Reply with quote
Hi Jolly,
I'll try to help...
In the Com Manager, select settings (the right hand bottom menu button) and choose bluetooth settings. You now get 3 tabs. Select the middle tab 'devices' and hold the stylus on the holux BT name (it should be there) and select edit. Ensure that the Serial Port option box is ticked. Then save. Now go to the 3rd tab 'com manager'. Is your Holux BT listed here*, it should be and it will have a com port next to it, normally (COM6). Hold the stylus on it and choose edit. Unselect the box 'secure connection'.
*If it is not listed then select new outgoing port and select the Holux. Unselect the box 'secure connection'.
Now try tomtom again using com 6 (or whatever com was listed in the 'com manager' tab). Give it 30 seconds or so just in case it's a little slow getting started for any reason.
If you still have problems, it may be worth deleting the existing pairing with the Holux and starting again with a new partnership.
Try this and let me know how you get on...
Jolly22969
PostPosted: Tue Sep 26, 2006 5:01 pm    Post subject: same problem Reply with quote
Hi Noony
i did the same first with the old pairing but didnt get positive result then i deleted the old pairing and made new but again negative. according to your instruction i did pair the phone with bluetooth and it detected on com 6 with serial port ticked and unchecked secure connection. but when configured it in tomtom it just gave me the same options:
com9
infrared port
com3
com 0
com 2
serial port
and i tried to configure it on all of them one by one and waited for more than 30 seconds but still have the same messege 'no gps device'
please help me out i am stuck. sorry for that bothering you again and again. hope you understand
Noony
PostPosted: Tue Sep 26, 2006 5:08 pm    Post subject: Reply with quote
Exactly what is listed under/in the 3rd tab 'com manager'
Alsoin your settings tabs (from the bottom of the start menu) do you have a GPS icon?
Noony
PostPosted: Tue Sep 26, 2006 5:28 pm    Post subject: Reply with quote
When your configuring/trying your GPS are you looking at the screen with the strength bars on it. On any of the Com settings, does the little yellow and black icon in the top right hand corner turn around?
Jolly22969
Hi Noony
when i go in the Edit - Comm Manager, there are 3 tabs, 1-Mode 2-Devices 3-Com Ports, in the com ports tab, the exact thing mentioned are:
BTGPS74R (COM6)
Incoming Port (Com7)
New Outgoing Port)
and there is no icon of gps under setting of phone.
Noony
PostPosted: Tue Sep 26, 2006 5:37 pm    Post subject: Reply with quote
What is the incoming port (Com 7) for? Can you delete it?
What about the yellow and black icon turning?
Jolly22969
i was configuring with the instructions on this web site:
http://www.tomtom.com/support/index.php?Language=1&FID=3236
but there is no sign of black/yellow sign moving and bars are empty/dead.
Noony
PostPosted: Tue Sep 26, 2006 5:49 pm    Post subject: Reply with quote
It may help to activate the GPS icon in the settings, it involves a registry hack, have you ever tweaked a PPC registry?
The tweak can be found here (scroll down to add GPS setting)
http://forum.pocketinfo.nl/showthread.php?t=71141
If you did this I could tell you what settings I use...
Jolly22969
i dont know what is for com7 i think i had installed activesync so it might be used for that but now i have deleted com7 and paired the phone again from the begining with bluetooth. then again tried to configured the tomtom but still there is no sign of moving black/yellow icon and gps status bars are empty/dead. a messege is 'no gps device' on top of screen
Jolly22969
PostPosted: Tue Sep 26, 2006 5:50 pm    Post subject: Reply with quote
thanks let me try this link then i let you know
Jolly22969
PostPosted: Tue Sep 26, 2006 5:54 pm    Post subject: Reply with quote
yes i am on 'Add Gps Setting Icone' now
Jolly22969
PostPosted: Tue Sep 26, 2006 6:09 pm    Post subject: Reply with quote
yes Noony i am on this section now and waiting
Add GPS settings icon
Noony
PostPosted: Tue Sep 26, 2006 6:29 pm    Post subject: Reply with quote
goto access tab and tick the box manage gps automatically
goto hardware tab and select GPS hardware port as Com6
and the baud rate as 4800
goto the programs tab and select the GPS program port as Com8
Exit and do a soft reset
Now retry Tomtom on both Com6 and Com8
Jolly22969
PostPosted: Tue Sep 26, 2006 7:02 pm    Post subject: Reply with quote
Sorry Noony couldnt find the Access tab and Hardware tab, please help...
Noony
PostPosted: Tue Sep 26, 2006 7:16 pm    Post subject: Reply with quote
have you done the gps icon registry tweak (described on the weblink I gave) and can you see a gps icon somewhere in the settings tabs?
Page 3 of 4
