Pocket GPS World :: View topic - TT5 and BT338 on XDA Mini S
Draz1e
PostPosted: Fri Sep 22, 2006 8:27 pm    Post subject: TT5 and BT338 on XDA Mini S Reply with quote
When pairing the BT 338 with my XDA Mini S the only two ports available are ports 6 & 7, however when I open TT5 and try and get it to see the Bluetooth receiver the only ports available are Com0, Com2,Com3, Com9, Infrared port and serial port. This is my first BT GPS unit so am I doing something wrong? Any help would be appreciated Sad
PostPosted: Fri Sep 22, 2006 8:30 pm    Post subject: Reply with quote
First of all are you trying to install TomTom Navigator version 5,21 - if not it won't work correctly on this device, you can download the program files from www.tomtom.com this will give you the latest updated files - Mike
Draz1e
PostPosted: Fri Sep 22, 2006 8:42 pm    Post subject: Reply with quote
Yes had to install V5.21 from TomTom site as could not install from cd, something to do with PDA running WM5.
PostPosted: Fri Sep 22, 2006 9:17 pm    Post subject: Reply with quote
First off check the e-mail address you have linked to this site as I have sent some details, otherwise you need to set up an outgoing port in the Bluetooth manager.
Start/ Settings connection tab Bluetooth "COMPorts" Tab and select New outgoing Port, select the GPS device from the list, press Next then assign the Com Port from the drop down list (in your case com7).
Now fire up TomTom and configre for com port 7 - Mike
Draz1e
PostPosted: Sat Sep 23, 2006 9:37 pm    Post subject: Reply with quote
many many thanks, although I had downloaded the 5.2x version onto the new phone, when I sync'ed it with my pc some old files had been copied across as well. cleared them all out and it all works a treat now. Thanks again Mike.
22.105 (30 Oct 24)
