Pocket GPS World :: View topic - See some data that's incorrect in the Comparison Databases ?
PostPosted: Thu Jan 01, 2004 12:08 pm    Post subject: See some data that's incorrect in the Comparison Databases ? Reply with quote
We try where possible to get the data as accurate as possible, but some manufacturers list some data where others don't. We'll try and collate as much information as possible, but sometimes information may be missed either due to no manufacturer information at the time of addition, or we have added new features to the database.
If you see some data that you believe is incorrect or missing in any of the Comparison Databases, please notify us of it here, and also try to supply as much information, like any URL's to other product specs to help us update the Comparison Databases.
matt_e
PostPosted: Sat Jan 10, 2004 12:05 pm    Post subject: Reply with quote
Fortuna BT Clipon comes with the following which are crossed out in the comparison table:
LANYARD - Hand Strap
CIGARETTE LIGHTER ADAPTER: In-Car charger with USB power cable
CARRY CASE: Clear carry case
REMOVABLE BATTERY: 1200mAh Li-Polymer Rechargeable Battery (8.5 hour runtime)
MAINS ADAPTER: UK and US mains adapter connections
Matt
PostPosted: Sat Jan 10, 2004 2:20 pm    Post subject: Reply with quote
Thanks, updated! Thumbs Up
Peter Kessler
PostPosted: Sun Jan 11, 2004 12:03 am    Post subject: Reply with quote
Rikaline X7: a mains charger is available as an optional extra. It's a 13 amp plug that can receive a cigarette lighter adapter.
DinAlt
PostPosted: Sun Jan 11, 2004 12:23 am    Post subject: Reply with quote
I can't post when I try to reply from the database page - trying as a direct reply to the pst.
Holx GR-230 - defualt data rate should be 9600.
My receiver came with an external antennae in the box as well.
DinAlt
PostPosted: Sun Jan 11, 2004 9:55 am    Post subject: Reply with quote
There's no difference in posting here, there or anywhere. The only issue would be if you usually use pocketgpsworld.com, you should be using PocketGPSWorld.com for consistency. If you were logged in under pocketgpsworld.com and not under PocketGPSWorld.com this would make a difference, but that's been the case since Sept 2003.
I have updated the Holux now, it should show 9600. Did you buy it direct from Holux UK ? I was told that the GR-230 wouldn't be shipped with an antenna, but Holux may have changed their mind seeing their CF cards ship with one.
simkna
PostPosted: Sun Jan 11, 2004 12:11 pm    Post subject: Reply with quote
Fortuna clip-on is listed as having no passkey. Mine uses 0000.
Si.
matt_e
PostPosted: Sun Jan 11, 2004 12:12 pm    Post subject: Reply with quote
Simkna,
Can you tell me. Does the clip on have a 5V 4mm DC jack as its power input?
Thanks,
Matt
DinAlt
PostPosted: Sun Jan 11, 2004 12:33 pm    Post subject: Reply with quote
My Holux came via e-bay but it did come with uk plug etc and antennae in sealed package within the box - may be different for UK market - seems a bit cheap of them if so...
DinAlt
PostPosted: Sun Jan 11, 2004 4:37 pm    Post subject: Reply with quote
Updated passkey Thumbs Up
leoseven
PostPosted: Sat Jan 17, 2004 10:09 am    Post subject: sysonchip BT GPS baud Rate ! Reply with quote
I Know it - 38,400 bps , No 9,600 bps
Smile
rossh51
PostPosted: Sun Jan 18, 2004 4:56 am    Post subject: Reply with quote
Powered cables are available for the Palm M515 and Dell Axim X5 for the Haicom 202E
Ross
PostPosted: Sun Jan 18, 2004 9:58 am    Post subject: Reply with quote
Leoseven, updated cheers.
Rossh51, are you sure the 202E supports PDA cables ? AFAIK the 202E was a USB only mouse, the 203E does support PDA cables though and supports both Dell and Palm cable sets. I can't find any retailers that are selling the 202E with a set of cables (only cables seperately for Haicom's).
rossh51
PostPosted: Sun Jan 18, 2004 11:59 am    Post subject: Reply with quote
You are correct. The packaging says 202E but I went to the car and checked unit and it is a 203E. My apologies for the incorrect post.
Ross
PostPosted: Sun Jan 18, 2004 12:04 pm    Post subject: Reply with quote
Thanks for the clarification. It's one of those areas where I have seen the GPS up close, but just couldn't remember, but from what I recall the 203 has the PS/2 connector that comes apart, but I thought the USB cable was integral and couldn't be converted.
Thanks!
23.083 (20 Aug 25)
