B0dger67 Occasional Visitor
Joined: Sep 14, 2006 Posts: 34 Location: Reading, Berkshire
Posted: Thu Sep 14, 2006 11:26 am Post subject: Problems with 2GB SD Card |
Long post, so bear with me...
I had my old GO700 stolen a while back and replaced it with a GO510 (a backward step in many ways). I persuaded TomTom to give me a new activation code from my MoWE that came with the GO700 so that I could use them on the new one.
To install the additional maps, I restored a known-good backup of my 510 to a new 2GB SD card, removed the GB maps and copied on my backed-up MoWE. Using the 510 through TomTom home, I entered the activation code they gave and MoWE was ready to go. I copied on some new .itn files and some voices, disconnected and undocked the TT and restarted it.
I got the splash screen, then it shut off. Each time I tried to start it the same thing happened. I put my old flash card in and it was fine so the hardware seems to be ok. With the new card back in I re-docked it and was agin able to use the MoWE through TT Home.
So, I thought that maybe I'd done something wrong or maybe there's an issue with my MoWE and this version of the TT. I formatted the flash through Windows Explorer and then did the restore again. Leaving the GB maps in place I found that the same thing happens - the splash screen comes up then the device shuts down - so it doesn't appear to be a map problem. Again, while docked I can use the installed maps OK through TT Home.
Anyone got any idea what's going on??? |
julianbarker Lifetime Member
Posted: Thu Sep 14, 2006 11:50 pm Post subject: |
What speed and make is the 2GB card? Where did you get it from? Is it genuine or a fake? |
dirtyweeraincloud Occasional Visitor
![](modules/Forums/images/avatars/gallery/121.gif)
Posted: Fri Sep 15, 2006 8:31 am Post subject: |
Thanks for the responses fellas...
Tried the flash tool as other posts seem to have it as the cure for all ills - no difference.
julianbarker wrote: | What speed and make is the 2GB card? Where did you get it from? Is it genuine or a fake?
It's a Veho 133x card bought from Ebuyer expressly for this purpose. I haven't tried peeling the label off to see who really makes it, but Ebuyer reckon its Samsung.
http://www.ebuyer.com/UK/product/114800/rb/21774869587
Yes, it was cheap, but it works ok in my PDA and the card reader in my PC. |
Posted: Fri Sep 15, 2006 8:33 am Post subject: |
Whoops, forgot to end Julian's quote above This should make more sense.
julianbarker wrote: | What speed and make is the 2GB card? Where did you get it from? Is it genuine or a fake? |
Macbobby Occasional Visitor
![](http://img1.jurko.net/avatar_1692.gif)
Posted: Fri Sep 15, 2006 9:10 am Post subject: |
Hi there. The same events you descride are similar to an old problem that used to happen with certain 2 gig SD Cards on firmware 6.10,6.11 and 6.12. Tomtom fixed it with firmware 6.15 ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Posted: Fri Sep 15, 2006 1:58 pm Post subject: |
Macbobby wrote: | Hi there. The same events you descride are similar to an old problem that used to happen with certain 2 gig SD Cards on firmware 6.10,6.11 and 6.12. Tomtom fixed it with firmware 6.15 ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
I can't find any reference to v6.15 on the TT web site - 6.11 seems to be the latest for the x10 series and that's what I have.
Am I missing something? |
shauneco Regular Visitor
![](modules/Forums/images/avatars/1734307015456c655d9c0e3.jpg)
Joined: Feb 10, 2006 Posts: 135 Location: Mansfield,Nottinghamshire
Posted: Fri Sep 15, 2006 2:32 pm Post subject: |
v6.11 is the latest version firmware for the x10 serie's v6.15 is for the older x00 serie's.
Their have been some compatibility problems with some SD Cards although mainly the standard speed cards. |
Posted: Fri Sep 15, 2006 3:26 pm Post subject: |
Ah yes I remember now I could not get my Viking 2.0GB to work in my new 510 (now returned) on firmware 6.11 so i changed device and upped the firmware to 6.15 and it worked fine. Unfortunately it kept drooping and falling off in my car so I got rid of it and I now have a TT ONE V2. The faster speed SD Cards are supposed to work with 6.11 |
Posted: Fri Sep 15, 2006 4:16 pm Post subject: |
So where did you get v6.15 from? I can't see any reference on the web site. |
Andy_P Pocket GPS Moderator
Posted: Fri Sep 15, 2006 4:41 pm Post subject: |
You were right when you posted before B0dger...
B0dger67 wrote: |
I can't find any reference to v6.15 on the TT web site - 6.11 seems to be the latest for the x10 series and that's what I have. |
Versions above 6.11 are for the OLD models.
Just like the maps, higher numbers do not NECCESSARILY mean newer/better content. |
Posted: Fri Sep 15, 2006 5:51 pm Post subject: |
Andy_P2002 wrote: | You were right when you posted before B0dger...
B0dger67 wrote: |
Indeed. Could not agree more!! As I said before I used firmware 6.15 on the 510 in order to use a 2.0GB SD Card that would not work with firmware 6.11 |
OrangeJuiceMan Occasional Visitor
![](modules/Forums/images/avatars/gallery/032.gif)
Joined: Jun 06, 2006 Posts: 39 Location: Adrift on the Sea Of Life
Posted: Sat Sep 16, 2006 2:37 pm Post subject: |
I am using a high-speed RiData Pro 2GB Card with my 510 under 6.11 - no problems at all. The source was an Australian eBayer who is an authorised dealer for RiData. There are many, many, fake/dodgy cards out there in eBayland and just coz it works with one device don't mean it will work with another - my source (I use him for a lot of memory chips of various types) recently had his auctions 'suspended' by eBay for "naming names" of the fakes suppliers... now there's justice!
OJM |
Posted: Sun Sep 17, 2006 3:23 pm Post subject: |
This came from Ebuyer - not eBay - a very reputable source. Maybe you could let us have the details of your supplier for future reference?
Thanks. |
Posted: Sun Sep 17, 2006 3:59 pm Post subject: |
The problem with sd cards was not a supplier issue it appeared to be a read speed issue. The Sd Cards I used were all branded, supplied in heat sealed packages. I won't mention the brands that didn't work because, as I said, the problem was corrected with firmware. But I will say that my Sandisk Ultra 2 worked on f/w 6.11 no problem ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
