pres Occasional Visitor
Joined: Mar 31, 2006 Posts: 17 Location: gloucestershire
Posted: Thu Sep 14, 2006 10:11 pm Post subject: Navman icn410 |
I will try once more. I have aNavman 510. Usinfg the appropriate download instructionsfrom Pocket gps,I downloaded the 4 progs onto the device. However I have discovered that when I shut the device down using the off switch at the back the programms are deleted.
Nowhere can I find any instructions to prevent this happening.
I have been persuing this problem since 6th June through the forum system with no success, so would appreciate some advice evn if it is throw the bloody thing in the river _________________ old fart |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Thu Sep 14, 2006 10:20 pm Post subject: |
Which four progs are these? You should use the On/Off button on the front of the unit to turn it on and off. _________________ Tim |
Posted: Fri Sep 15, 2006 9:19 am Post subject: navmanicn510 |
Hi Tim. firstly the recommendation by navman is to turnit off at the back if it is not being used for some time as it drains the battery.
Secondly the four progs are:-
Pocket gp.bm
.chk
.ini
.map
In explore mode they show as separate items and do not appear in pois or my pois.
hope this helps _________________ old fart |
Posted: Fri Sep 15, 2006 9:27 am Post subject: |
OK, turning off at the back 'resets' the unit and, I believe, deletes all user information. Does your 'Home' position also disappear? _________________ Tim |
Posted: Fri Sep 15, 2006 6:04 pm Post subject: navmanicn510 |
tim sorry I don't understand what you mean by home position. can you explain
By the way I checked that the progs were still on the device this morning ,went past a camera in Cirencester but there was no warning either visible or audible _________________ old fart |
Posted: Fri Sep 15, 2006 6:15 pm Post subject: Re: navmanicn510 |
pres wrote: | tim sorry I don't understand what you mean by home position. can you explain
By the way I checked that the progs were still on the device this morning ,went past a camera in Cirencester but there was no warning either visible or audible |
Have you set your 'Home' location? i.e. do you get the option to navigate to 'Home'? If you have, does that option also disappear after using the rear On/Off switch? _________________ Tim |
Posted: Sat Sep 16, 2006 10:39 am Post subject: navman icn510 |
Hi I set home destination , switched off at the back,lost camera download but home destination still there. _________________ old fart |
