andyjenkins Regular Visitor
Posted: Fri Sep 08, 2006 12:24 am Post subject: |
Can anyone enable the logging? When trying to turn it on - all I get is a prefilled log filename - the directory chooser and a cancel button.
There's no way of 'confirming' the file to log too.
Am I missing something ? _________________ --
Got Broadband? |
tchart Regular Visitor
![](modules/Forums/images/avatars/419195797429cd4c89c7c1.gif)
Joined: Apr 06, 2005 Posts: 121 Location: Wellington, New Zealand
Posted: Fri Sep 08, 2006 12:45 am Post subject: |
Andy,
What OS are you running? You should get an "OK" button on the top right of the taskbar. If you arent then something is obviously wrong.
Ive just tested on my WM 2003 device and its works (my WM5 device is at home so I cant test that one right now).
The file name dialog uses GSgetfile (since the MS file browser limits you to certain directories).
Regards
Trevor Hart _________________ Tchart Development
www.tchartdev.com |
Posted: Fri Sep 08, 2006 12:46 am Post subject: |
Sorry, I forgot to mention that you should be able to press "OK" on the D-pad to dismiss the dialog once youve selected a filename.
Regards
Trevor _________________ Tchart Development
www.tchartdev.com |
Posted: Fri Sep 08, 2006 1:02 am Post subject: |
Bah .. OK - lets disregard this ... I'm on Windows 2005 (recently upgraded) and missed the 'OK' in the top (top) right (ie, above the 'Cancel' button).
Sorry Trevor.
One suggestion I have .. not sure if it goes against what you see in the product's development. Is the max speed line in the speed graph. Can this be customisable? Ie, personally, I don't find historic max speed limit that useful, and I would prefer to have a choice - maybe, rolling, or sampled average speed ? _________________ --
Got Broadband? |
wiz Regular Visitor
![](modules/Forums/images/avatars/113930636546c977eb3500f.jpg)
Joined: Aug 08, 2005 Posts: 241 Location: Dartford, Kent, UK
Posted: Fri Sep 08, 2006 10:07 am Post subject: |
Thank for the tip Alan Will Try That later today
Use a BT Receiver that’s virtually on all the time so a restart wouldn’t be a bad idea
Regards Wiz aka ALAN ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Posted: Sat Sep 09, 2006 11:29 am Post subject: |
Andy,
Regarding your suggestion about the graphs, in order to make some real estate for the speed camera database display I intend to combine the current graphs into one "screen".
The revised graph screen will be able to be switched between the current speed & elevation graphs and a few more new ones which I will be adding. I will look intio making ones of these a current speed vs average speed.
If you have any suggestions for other graphs you would like to see feel free to let me know.
Regards
www.tchartdev.com |
cyrilwad Occasional Visitor
Posted: Sun Jan 14, 2007 12:39 am Post subject: |
Hi Trevo
I have just bought and installed GPS Speed Sentry into
my MIO168, It won't find any GPS signal,I have tried
COM 5 as they suggest but it will not work.
Have i wasted my money.
Cyril |
alan_sh Lifetime Member
Posted: Sun Jan 14, 2007 3:34 pm Post subject: |
Try COM8 - that's what works on my IPAQ |
wiz Regular Visitor
Posted: Sun Jan 14, 2007 10:16 pm Post subject: |
com 8 works for me also ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Posted: Mon Jan 15, 2007 12:58 am Post subject: |
cyrilwad,
while you are trying COM ports, take a look at the status screen (the last icon). Do all 3 of the dots flash or stay green? These represent the NMEA sentences the application is expecting.
Some people have had issues with the MIO without the latest firmware. The latest firmware turns the required sentences on (there is another method too).
If you want some help via email you can get my address of my website (www.tchartdev.com)
Regards
www.tchartdev.com |
Posted: Mon Jan 15, 2007 9:51 am Post subject: GPS speed sentry |
Thanks for all the help everybody,
It just tells me that (could not open port! port may already be open)
and the three yellow lights on the right don't change colour at all,
i have tried all the ports.
Thanks Guys
Cyril. |
Posted: Mon Jan 15, 2007 10:12 am Post subject: |
Cyril,
Do you know what firmware version you are running? Is it 2.3 or 2.4?
Try COM2 with baud rate of 4800 and also try 9600. I have reports of both working (depending on the firmware version).
Regards
www.tchartdev.com |
Posted: Mon Jan 15, 2007 11:58 am Post subject: |
Hi Trevor
Sorry i'm a pain ,it still will not work'
how do i find out what version i am using
co's iv'e no idea.
cyril |
Posted: Mon Jan 15, 2007 8:49 pm Post subject: |
Cyril
Okay, I must have misread the post. If you are getting a "Cant open port message" the port is probably in use by another program. There is an operating system limitation in Windows Mobile which only allows one program to use a COM port at a time.
Are you running any other GPS applications like TomTom? make sure they are closed properly - merely clicking the X to close the app doesnt always close the app properly
An easy way to ensure nothing else is running is to give you device a soft reset. After it boots up, start GPS Speed Sentry and see if you can connect to COM2.
Regards
www.tchartdev.com |
Posted: Mon Jan 15, 2007 11:59 pm Post subject: |
Hi Trevor
Thank you, It now works on Com 5,
the only trouble is now my Tom Tom won't
work.
I guess i will have to do a reset each time i
change between the two programs unless i can find
a way to disable the com ports that it says are working.
THANK YOU.
Cyril |
