Pocket GPS World :: View topic - Mapsource Metroguide Europe V7
01101000_01101001
PostPosted: Mon Sep 04, 2006 5:25 pm    Post subject: Mapsource Metroguide Europe V7 Reply with quote
Sorry i bet this has been asked 1000 times already but i cant find anything when i search. Can i use Mapsource Metroguide Europe V7 as a routable map on my i3?
Or is is there a better way to find my way to Italy?
Thanks Ian
zogman
PostPosted: Mon Sep 04, 2006 5:34 pm    Post subject: Reply with quote
only if you load the maps using a program called img2gps...theres a few threads re using this software,do a search..
missing_user
PostPosted: Mon Sep 04, 2006 6:00 pm    Post subject: Re: Mapsource Metroguide Europe V7 Reply with quote
Thanks Ian
Strange you searched and found nothing!!!!
I found 150.
Here are two:-
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=40185&highlight=metroguide
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=43685&postdays=0&postorder=asc&start=15
01101000_01101001
PostPosted: Mon Sep 04, 2006 6:05 pm    Post subject: Reply with quote
lucky you....
missing_user
PostPosted: Mon Sep 04, 2006 6:27 pm    Post subject: Reply with quote
lucky you....
I pressed the search button, chose metroguide, saw 150, selected two, posted the links to help you and I get an answer like that!!! Rolling Eyes
01101000_01101001
PostPosted: Mon Sep 04, 2006 6:31 pm    Post subject: Reply with quote
ok then unlucky you
afterall
PostPosted: Mon Sep 04, 2006 6:56 pm    Post subject: This will do it. Reply with quote
I have been through this exercise and got some excellent from beerbelly.
You will need an sd card to send your map selections to, so I assume you have got one. I have 512mb card and I can fit a large number of France maptiles onto it and use up only about 110mb of card space.
You will need a copy of IMG2GPS so do a search of this forum and you find a link to it.
The instructions also make ref to Sendmap20 and this is included within the IMG2GPS download. If you look in the folder where you save IMG2GPS you will find Sendmap20. Just double click to launch.
The only changes I made from the following instructions, were under step 4 click select all to select all map tilesets, and step 9 I saved the image to the sd card first and then did a cut and paste into the Garmin folder on the sd card.
When complete you can check that your maps are on your satnav by going into settings, choose maps, mapsource and check that you have your basemap plus the selection imported using Sendmap20.
Follow the instructions below.
1 - Select the MapTiles visually in Mapsource and upload them to the SD card in the unit [60 CSX], or preferably a SD card in a card reader [using Send to Device]. This will create a full indexed, but non-auto routable MapSet [look for gmapsupp IMG file]. This takes quite a while for a large MapSet!
2 - Also Save the MapSet selection as a .gdb file from MapSource in My Documents.
3 - Launch IMG2GPS and use the "load" option at the bottom of the screen to load the .gdb file. [from #2] It will show the list of all the MapTiles.
4 - Check the two options "Folder/Card" and "Create File instead of Upload" and then
5 - Click on "Create File". This will create an auto-routable, but non-indexed/non-searchable MapSet in My Documents. [look for GMAPSUPP IMG file in My Documents]
6 - Launch Sendmap20 and use the "add map" option to load the gmapsupp IMG file [from#1] It will list all the map tiles and will also list an index file at the end.
7 - Now highlight the first map tile in the list and hit the "Ctrl + delete" button until you have removed ALL the maps except the "index" file.
8 - Now use the "add map" option again, to load the GMAPSUPP.IMG file that was created by IMG2GPS [in My Documents from #5]. Now your list will include all the routable map tiles and the index file.
9 - Click on the send to GPS or Save to SD card [depending on the unit]
This will be auto-routable and fully indexed.
If you have any problems pm meand I will see if I can help.
01101000_01101001
PostPosted: Mon Sep 04, 2006 8:18 pm    Post subject: Reply with quote
Thats great thanks for your help guys
Ian
Anita
PostPosted: Mon Sep 04, 2006 8:57 pm    Post subject: Reply with quote
ok then unlucky you
It could be unlucky you next time you want some help, and the people with the knowledge and experience to offer that help remember your attitude. Rolling Eyes
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
mk_graham
PostPosted: Mon Sep 04, 2006 9:23 pm    Post subject: Reply with quote
Hmmm, watching this post earlier - thought I might help this guy, then saw his rudeness come out, so decided not to help.
'afterall', you are clearly more tolerant than I.
Loving the avatar that 00000000 (or whatever his handle is) is using, but then thought 'now, what kind of name is 'Ian' for a PIMP?'
luck on your next request for info, brother Twisted Evil
Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems
Beerbellybill999
PostPosted: Tue Sep 05, 2006 2:36 pm    Post subject: Reply with quote
I use a utility called Metrowizz to upload metroguide to my i3.
works a treat and far easier that img2gps method.
It can be downloaded at http://www.geodude.nl/gps/index.php
Maps are fully routable with search facility
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
afterall
PostPosted: Tue Sep 05, 2006 6:18 pm    Post subject: I'll give it a try Reply with quote
Thanks for the link beerbelly, I will try this program out.
Re the previous tit for tat, I don't think that people are always trying to be rude when the backchat starts, it sometimes just gets taken the wrong way.
Come on we are all here to help each other!!
A
missing_user
PostPosted: Tue Sep 05, 2006 7:16 pm    Post subject: Re: I'll give it a try Reply with quote
Once maybee, but twice!!!
Anyway this statement was suspect:-
I've learnt a valuable lesson, don't waste time on topics that I have covered before!!!
zogman
PostPosted: Wed Sep 06, 2006 9:26 am    Post subject: Reply with quote
i tend to agree with you strumble...nearly every day someone asks a question which with a search will come up with an answer....there are stickies above and camera help guides to the left of the page...for newbies with few posts to there name , these should answer every query....sometimes a newbie will look and not be able to find anything ,so a polite 'steer' to the search engine or a 'brief' explanation does help...
afterall
PostPosted: Wed Sep 06, 2006 9:37 am    Post subject: Metrowizz is a wizz Reply with quote
Used Metrowizz last night to load up my maps of France and Spain, piece of cake to use and was able to transfer directly to the connected i3 and saved mapsets straight to the installed 512mb sd card.
Much easier than the method I posted above, so just follow the wizard instructions included within the program.
A
22.062 (12 Jun 24)
