robbooth Lifetime Member
![](modules/Forums/images/avatars/13854071505106963a2397f.gif)
Posted: Thu Aug 31, 2006 9:07 am Post subject: i3 Battery Options |
If the i3 doesn't charge from the in car power lead, what difference does the battery option (alkaline or NiMh) in the setup menu do? |
Ash10 Pocket GPS Verifier
![](modules/Forums/images/avatars/766726342477fdefb3500b.jpg)
Posted: Thu Aug 31, 2006 9:26 am Post subject: Re: i3 Battery Options |
robbooth wrote: | If the i3 doesn't charge from the in car power lead, what difference does the battery option (alkaline or NiMh) in the setup menu do? |
Alkaline and NiMh batteries have slightly different voltages and discharge characteristics.
It doesn't really matter which option you have it set to - it's just there to try and make the battery level indicator more accurate. |
Mr_Gonzales Regular Visitor
Joined: Oct 05, 2005 Posts: 123 Location: Mmm...medway
Posted: Thu Aug 31, 2006 1:57 pm Post subject: |
But regardless of what option you select, most i3s will get down to two bars (out of the four possible), flash up the low battery warning and turn off ten minutes later. Accuracy is not a strong point on that battery guage. |
Posted: Thu Aug 31, 2006 2:08 pm Post subject: |
Mr_Gonzales wrote: | But regardless of what option you select, most i3s will get down to two bars (out of the four possible), flash up the low battery warning and turn off ten minutes later. Accuracy is not a strong point on that battery guage. |
I did say that it was there to try to improve accuracy - I didn't say that it actually worked ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Thu Aug 31, 2006 2:18 pm Post subject: |
you'll also find that when running on batteries , (and the batteries are low) any voice navigation will shut done the unit due to the power drain... _________________ *************************** |
pgatens Occasional Visitor
Posted: Mon Sep 04, 2006 4:56 pm Post subject: |
I find that my i3 (fitted to my triumph Tiger motorcycle with power lead) goes mad when the internal batteries levels fall. First i get a bleeping noises and then it tries to turn itself off and then comes back on again
paul
hertford |
