Pocket GPS World :: View topic - tom tom sd card
tom tom sd card
coblator
PostPosted: Sat Aug 26, 2006 8:24 pm    Post subject: tom tom sd card Reply with quote
i have bought a new 512mb sd card for my tom tom go 300 and my tom tom will not recognise it it just keeps comming up wrong card when i insert it data from my 256mb card has been transfered ok can anybody advise
nascar9
PostPosted: Sat Aug 26, 2006 8:55 pm    Post subject: Reply with quote
Have you checked the card is not locked i.e. that it is write enabled.
Your TT has to be able to write to the card.
999tommo
PostPosted: Sat Aug 26, 2006 10:13 pm    Post subject: Reply with quote
It depends on how you copied your files to your new card. I find the best way is firstly to ensure that your browser has the 'show hidden files and folders' box checked. Then create a folder on your PC and copy everything from your old SD card to that folder. Finally copy everything from the folder on your PC (not the folder itself, only the contents) to your new SD card. It should then work.
REMEMBER, before you make any changes, perform a full backup.
Tommo...
Regularly absent, but still here in spirit !
coblator
PostPosted: Sat Aug 26, 2006 10:49 pm    Post subject: Reply with quote
THANKS FOR THE REPLY ON THE NEW CARD THE WRITE ENABLE IS RIGHT
I HAVE LOADED THE CARD FROM MY 256K AS INDIVIDUAL FILES AND WHEN I CHECK THE CARD ON THE COMPUTER TO CHECK THAT WHAT I HAVE PUT ON THE CARD IS THERE AND IT IS BUT WHEN I PUT IT IN THE TOM TOM I GET A RED CROSS TO SAY THAT IT IS THE WRONG CARD
PostPosted: Sat Aug 26, 2006 11:26 pm    Post subject: Reply with quote
There are some SD Cards that are giving trouble when used with a TT.
What Card do you have?
And is it a High Speed one?
coblator
PostPosted: Sun Aug 27, 2006 1:28 pm    Post subject: Reply with quote
HI RICHARD
THE SD CARD I AM USING IS AN ORDINARY SANDISK MEMORY CARD AND IT DOESENT SAY HI SPEED
PostPosted: Sun Aug 27, 2006 9:45 pm    Post subject: Reply with quote
I believe that have been found to cause problems with TT.
I currently use a ByteStor Hi-Speed, and I've had no trouble with it.
Could you turn your Caps Lock off please. You're deafening everyone.Smile
999tommo
PostPosted: Sun Aug 27, 2006 9:58 pm    Post subject: Reply with quote
I use a Sandisk 1GB card. It doesn't say what speed it is and I don't know how to find out, but I have never had a problem with it.
Did you ensure that the 'show hidden files and folders' box is definately checked in your windows explorer ? If not there may be a crucial file that you are not copying over and even though you have checked the contents of both cards to ensure they are the same, if this box is not checked, you WILL NOT be copying everything.
Open 'My Documents', click 'Tools', then 'Folder Options'. Click the 'View' tab and under 'Hidden Files and Folders', make sure the 'Show hidden files and folders' check box is definately checked. If the 'Do not....' box is checked, you will not transferring all the necessary files over.
Good Luck Wink
Tommo.
Tommo...
coblator
PostPosted: Sun Aug 27, 2006 10:59 pm    Post subject: Reply with quote
hi tommo
checked the folder options but still no go i think it must be a problem with the cards i am using because i have added to the origianal card no problem bu now it is full thats the reason i wanted a bigger card so i am scratching my head now thinking what to do next
thanks phil d
rugrat2
PostPosted: Mon Aug 28, 2006 9:54 am    Post subject: Reply with quote
Do you know anyone else with a go 300 you could then try it in theirs!!
Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go..
Tumbleweed
PostPosted: Mon Aug 28, 2006 11:14 am    Post subject: Reply with quote
coblator wrote:
hi tommo
thanks phil d
Here's what is working in my 300
http://www.amazon.co.uk/gp/product/B00008SCFU/202-5229055-2909453?v=glance&n=560798
Was £11.60 now £4.20! (plus P&P)
Tw
ColinS
PostPosted: Mon Aug 28, 2006 7:15 pm    Post subject: Reply with quote
Be warned, this is not sold by Amazon but by a third party. I ordered a Kingstom SD card from them and after over a month of email ping pong I cancelled and ordered another make from someone else. Following this cancellation they ignored it and sent it to me by return saying it was too late to cancel as it had been dispatched, so I ended up with two.
I wouldn't touch these with a barge pole.
Colin
Honda Jazz EX-Navi MKIII
mdhazell
PostPosted: Mon Aug 28, 2006 9:13 pm    Post subject: Reply with quote
I had a similiar problem to start with on my SD card. I formatted it to FAT16 using Windows XP and it worked fine after that. It's possible that the card is formatted to NTFS but the TomToms use Linux.
Mark
TomTom One
Tumbleweed
PostPosted: Tue Aug 29, 2006 2:24 pm    Post subject: Reply with quote
Thats unfortunate, mine came in less thana week (I remember because I was waiting as my 300 kept crashing with a nearly full original card).
Anyway, at least the OP will know that make should be good for a 300.
tw
Cornflake
PostPosted: Thu Aug 31, 2006 11:38 am    Post subject: Reply with quote
Linux as an OS can handle just about any filesystem, including NTFS (to the extent that M$ bother documenting it, anyway), but more to the point is that SD cards are pretty universally formatted as FAT16 or FAT32 if the size warrants it.
Even cameras would expect a FAT formatted card, so it's generally true to say that any CF/SD card will be using a FAT filesystem - as purchased.
FWIW I'm using a cheap & cheerful Kingston 512MB card in my TTGO300 - no problems at all. I just shoved it in and started using it.
22.062 (12 Jun 24)
