trevf Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_001.gif)
Posted: Sat Aug 26, 2006 1:29 am Post subject: Mio C210 European Maps |
Hi all,
I am ready to be flamed for being a happy Garmin user... but one of my friends has ignored all of my advice and not bought a Garmin unit. Instead he has brought a Mio C210. He has asked me to have a look at it and as much as it pains me to say it, it aint bad!!! (that took a lot of effort so you guys had better help)
Anyway... enough sucking up!
He has a problem (other than not listening to me) which is that he is trying to load the Spanish maps onto an SD card. I have done this for him as he does not have an SD Card reader using the tools on the providded DVD. I have manually created a MioMap\Maps folder in the route of the SD card. The app has then created the following files:
In Miomap/Maps
Andorra.fbl
Basemap.fbl
Portugalia.fbl
Spain.fbl
WestEUMajor.fbl
and in the Root folder
license.db
and an empty directory gpslog
So far so good.
We have put the SD Card into the C210 and it rboots itself, but not a lot else happens. The new Map does not show under About, Maps. And when looking at Spain no more detail is available.
I'm guessing that we are missing a step but the instructions are worse than hopeless and I can't seem to see any related threads in this forum (which probably mans that it is a really obvious step that we are missing).
Could someone please help us by letting us know what else we need to do?
Many thanks for your time and help.
Trev _________________ Garmin i3
Firmware 3.4 |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Sat Aug 26, 2006 4:05 pm Post subject: |
the license.db file is bound to the SD card ID. You can't simply copy it over from somewhere else. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sat Aug 26, 2006 9:40 pm Post subject: |
The unit didn't come with an SD card, the british maps were installed already. It came with a DVD with the European maps which say they can be installed on an SD card which is what i am trying to do.
Please help
Firmware 3.4 |
Posted: Sat Aug 26, 2006 9:53 pm Post subject: |
lbendlin wrote: | the license.db file is bound to the SD card ID. You can't simply copy it over from somewhere else. | We didn't copy the Licence.db file the DVD software created it itself. _________________ Garmin i3
Firmware 3.4 |
linknet Frequent Visitor
Posted: Sun Aug 27, 2006 3:48 am Post subject: |
trevf wrote: | It came with a DVD with the European maps which say they can be installed on an SD card |
That's interesting. On how many SD cards can you install that? Logically they should limit that to just one card, otherwise the whole iGO licensing schema could be easily circumvented by someone with the Miomaps DVD and a few thousand SD cards. _________________ Lutz
Posted: Sun Aug 27, 2006 9:40 am Post subject: |
lbendlin wrote: | trevf wrote: | It came with a DVD with the European maps which say they can be installed on an SD card |
That's interesting. On how many SD cards can you install that? Logically they should limit that to just one card, otherwise the whole iGO licensing schema could be easily circumvented by someone with the Miomaps DVD and a few thousand SD cards. |
As far as I am aware MioMap will run on these devices without the SD at all, in fact I don't think that they come with an SD card. So MioMap must be licensed to the device itself and the license on the SD card must be just for the additional maps.
Regards
Roger |
Posted: Sun Aug 27, 2006 2:12 pm Post subject: |
yes, so far so good. The device behaves like a SD card in regards to the licence.db mechanism.
But there is an option to copy maps from DVD to SD (rather than to the device) - right?
In this case, how many SDs can be created this way? _________________ Lutz
Posted: Sun Aug 27, 2006 3:39 pm Post subject: |
If everything was done right, any ideas why it isn't working?
trev _________________ Garmin i3
Firmware 3.4 |
Posted: Sun Aug 27, 2006 3:51 pm Post subject: |
My theory is that the generated licence.db is invalid. _________________ Lutz
Posted: Sun Aug 27, 2006 5:11 pm Post subject: |
lbendlin wrote: | My theory is that the generated licence.db is invalid. |
In that case the maps still show as unlicensed and you get a message about some of the maps requiring a license.
Quote: | In this case, how many SDs can be created this way? |
As many as you like presumably.
Regards
Roger |
Posted: Sun Aug 27, 2006 5:19 pm Post subject: |
trevf wrote: |
You could try copying the generated license.db file to the MioMap folder on the SD card, if that doesn't work copy it to the Maps folder as well. Other than that format the SD card and do it all again, maybe there was a copying error.
Regards
Roger |
Posted: Sun Aug 27, 2006 5:24 pm Post subject: |
linknet wrote: | trevf wrote: |
Regards
Roger | I will give that a try. Just a point though, the Licence.Db file is 0kb is that normal? _________________ Garmin i3
Firmware 3.4 |
Posted: Sun Aug 27, 2006 5:31 pm Post subject: |
trevf wrote: | I will give that a try. Just a point though, the Licence.Db file is 0kb is that normal? |
No, that's not normal. That's your problem.
Regards
Roger |
Posted: Sun Aug 27, 2006 8:42 pm Post subject: |
linknet wrote: | trevf wrote: | I will give that a try. Just a point though, the Licence.Db file is 0kb is that normal? |
Regards
Roger |
Thanks Roger,
The file was created by the installer on the DVD how do i go about creating the correct one for the SD card?
Thanks Again
Firmware 3.4 |
