Pocket GPS World :: View topic - My One in TomTom HOME
jsinglet
PostPosted: Fri Aug 18, 2006 6:36 pm    Post subject: My One in TomTom HOME Reply with quote
I have just upgraded my TTONE to 6.15 and through HOME (just installed), when I click on My ONE it says that I have to download an additional component. The download always fails. Confused
Is anyone else having this problem?
TIA
James
Oldboy
PostPosted: Fri Aug 18, 2006 9:41 pm    Post subject: Reply with quote
The additional component allows you to run the Device on the PC Screen as a Virtual PND.
I didn't have any problems downloading or installing, so can't help further on that.
What error message do you get, and is from HOME or the PC?
jsinglet
PostPosted: Mon Aug 21, 2006 2:07 pm    Post subject: Reply with quote
The error message is from HOME, it seems that it cannot download a zip file. My wife has it in the car today so I can't try again.
The only thing I can think of is that I am going through a company firewall and there may be some restirction that is stopping it.
If I could find out the full address then I could try downloading it outside of home, but the URL in the error dialog is truncated. Sad
jblackmore
PostPosted: Mon Aug 21, 2006 5:00 pm    Post subject: Reply with quote
I had the same problem using TT Home 1.03 to upgrade my ONE from work, it cannot cope with a proxy server, which most companys will use.
I emailed Tom Tom for help, and they were useless, and suggested I use TomTom HOME to upgrade :-)
TomTom HOME 1.03 only seems to work from a direct broadband connection.
I did download this update and can't see why anyone would bother, as you can only use My TomTom when you have your real ONE connected by USB cable (as soon as you disconnect usb cable, the HOME icon greys out), so its completely pointless as far as I can see ??
UPDATE: It seems TomTom have fixed this in newer versions of Home, a friend tipped me off about this, as they updated through a proxy server, so tried this again today with TomTom Home 1.5 and it works fine, so wanted to update this !
Currently using TomTom ONE v3 and Live 1005 Camper
jsinglet
PostPosted: Mon Aug 21, 2006 6:09 pm    Post subject: Reply with quote
Any idea how big the download is, I'm only on dial-up at home
julianbarker
PostPosted: Wed Aug 23, 2006 10:40 pm    Post subject: Reply with quote
It worked eventually for me using dialup - the download took about 20 minutes, but I had to do it three times. The download failed half way through the first two times.
Even then I had to reboot the computer before Home would work properly.
TuurG
PostPosted: Wed Aug 23, 2006 11:18 pm    Post subject: Reply with quote
exiting HOME from system tray and then restarting HOME would have done the same trick as restarting the computer
GO1005
MGC GT 1968
MGB Cabrio 1973
