jsinglet Lifetime Member
Posted: Fri Aug 18, 2006 6:36 pm Post subject: My One in TomTom HOME |
I have just upgraded my TTONE to 6.15 and through HOME (just installed), when I click on My ONE it says that I have to download an additional component. The download always fails.
Is anyone else having this problem?
TIA
James |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Fri Aug 18, 2006 9:41 pm Post subject: |
The additional component allows you to run the Device on the PC Screen as a Virtual PND.
I didn't have any problems downloading or installing, so can't help further on that.
What error message do you get, and is from HOME or the PC? _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
Posted: Mon Aug 21, 2006 2:07 pm Post subject: |
The error message is from HOME, it seems that it cannot download a zip file. My wife has it in the car today so I can't try again.
The only thing I can think of is that I am going through a company firewall and there may be some restirction that is stopping it.
If I could find out the full address then I could try downloading it outside of home, but the URL in the error dialog is truncated.  |
jblackmore Regular Visitor
Joined: Nov 22, 2004 Posts: 137 Location: Somerset, UK
Posted: Mon Aug 21, 2006 5:00 pm Post subject: |
I had the same problem using TT Home 1.03 to upgrade my ONE from work, it cannot cope with a proxy server, which most companys will use.
I emailed Tom Tom for help, and they were useless, and suggested I use TomTom HOME to upgrade :-)
TomTom HOME 1.03 only seems to work from a direct broadband connection.
I did download this update and can't see why anyone would bother, as you can only use My TomTom when you have your real ONE connected by USB cable (as soon as you disconnect usb cable, the HOME icon greys out), so its completely pointless as far as I can see ??
UPDATE: It seems TomTom have fixed this in newer versions of Home, a friend tipped me off about this, as they updated through a proxy server, so tried this again today with TomTom Home 1.5 and it works fine, so wanted to update this ! _________________ --
Currently using TomTom ONE v3 and Live 1005 Camper
Posted: Mon Aug 21, 2006 6:09 pm Post subject: |
Any idea how big the download is, I'm only on dial-up at home |
julianbarker Lifetime Member
Posted: Wed Aug 23, 2006 10:40 pm Post subject: |
It worked eventually for me using dialup - the download took about 20 minutes, but I had to do it three times. The download failed half way through the first two times.
Even then I had to reboot the computer before Home would work properly. |
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Wed Aug 23, 2006 11:18 pm Post subject: |
exiting HOME from system tray and then restarting HOME would have done the same trick as restarting the computer _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
