Pocket GPS World :: View topic - Upgrading CS6 to CS7 & CN8
Goto page Previous  1, 2
oddsock
PostPosted: Tue Aug 15, 2006 7:41 pm    Post subject: Reply with quote
bumpkin wrote:
oddsock wrote:
My laptop also only has a CD drive but I'm pretty sure I'll be able to install from the DVD drive in my main PC across my network.
But does that apply once you are on route??
Surely once the mapping data is loaded onto the laptop it's irrelevant. It would be a full install.
Yes your right !! its just me with my "Thick" hat on today Embarassed Laughing
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
Aladdin_Sane
PostPosted: Tue Aug 15, 2006 7:51 pm    Post subject: Reply with quote
Does your DVD actually say it's CN8 Europe NT, the one on the Garmin site (probably inaccurate) appears to be plain CN8 Europe.
Yep, my disc says 'City Navigator NT+ Europe v8'
bumpkin
PostPosted: Tue Aug 15, 2006 8:31 pm    Post subject: Reply with quote
Worth a call to customer support I reckon, if enough people have complained they might be giving out or exchanging for plain CN8, with it's short-comings (not full Europe on unit), on the quiet. Gotta be worth a try?
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
bumpkin
PostPosted: Fri Aug 18, 2006 5:49 pm    Post subject: Reply with quote
I emailed customer support at Garmin Europe (via the on-line form) to ask if it would be possible to upgrade to V7 (disk sourced by myself) and then upgrade to V8, also asked that if this were possible what would be the effect on upgrade cost seeing as I've only just registered my Quest with CS6.
I got this reply just as short while ago:
Garmin European Product Support wrote:
Thank you for contacting Garmin Europe.
You would only be able to upgrade to version 8 but all of the mapping that
was included in the version 7 update will be also included in version 8.
Even though the mapping tiles are slightly larger in version 8, the actual
file size for each map tile is smaller so it will not take up anymore room
compared to version 6.
This flies very much in the face of oddsock's test he carried out earlier in this thread which showed that a sample long route returned a map set, using v8 over 2.5 times that for the same route using v6.
I'm going to reply stating the above example and see what they say.
Chas
oddsock
PostPosted: Fri Aug 18, 2006 7:31 pm    Post subject: Reply with quote
You had me worried that I still had "that" hat on when I posted the milages so I have just rechecked and they are correct!..If anyone else with v6 an v8 wants to give it a go and put my mind at rest ...select the two point with the route tool , let it calculate the route then select all the tiles that route passes through in as tight a corridor as possible and compare the two .
Garmin Quest
BrunoSoares
PostPosted: Fri Aug 18, 2006 7:43 pm    Post subject: Reply with quote
Hi there, I have a .xls file that compares the size of each country with diferent versions of Mapsource (CS6, CS7 and CN8)
Put the things this way...
With CS6 I could load the entire maps ou Portugal, Spain and Switzerland, plus Southern France and Northern Italy;
With CS7, northern Italy just couldn't fit in the 243 Mb of the Quest 1
With CN8 there's only room available for Portugal, Spain and Southern France.
But the time it takes processing information is almost the same comparing CS6 with CN8
One thing I do is loading diferent mapsets in order to optimize the short memory of the Quest:
When I want only the main roads of a certain place I load the CS6 maptile and when more acurate information is needed just load the corresponding CN8 maptile.
If you want the .xls file just PM and I'll send it to you !
bumpkin
PostPosted: Fri Aug 18, 2006 8:14 pm    Post subject: Reply with quote
Hmmm... Portugal and Spain, if I recall correctly, don't have a great deal of detail so surely their data doesn't amount to a great deal. In a rough cut using CS6 (all I have at the moment) Spain & Portugal amounts to around 87MB, France is over 200MB and Northern Italy is 90MB approx (down to Siena). The proportions should be similar for CN8 though probably marginally bigger for each.
It's not really whole countries that worry me, they'll be a bit bigger but the whole of the UK should still fit, it's long European route corridors being forced to include far more mapping either side due to the larger map tiles in CN8. I get where you're coming from with using mixed tiles from various versions, that's the approach I'll be taking though I would prefer to do that with CS7 than CS6. That's if I can get an unlock for CS7 upgrade along with the unlock for CN8 which is due from Garmin as a free upgrade. If I have to pay for the CS7 unlock then, I'm not sure how much it is ($75 = £40 or is there the normal 'European levy'?), I will consider sticking with a combination of CS6 and CN8.
Chas
missing_user
PostPosted: Sat Aug 19, 2006 10:05 am    Post subject: Reply with quote
="bumpkinHmmm... Portugal and Spain, if I recall correctly, don't have a great deal of detail so surely their data doesn't amount to a great deal. In a rough cut using CS6 (all I have at the moment) Spain & Portugal amounts to around 87MB [V8 will be 170MB], France is over 200MB [V8 will be 345MB] and Northern Italy is 90MB approx (down to Siena). The proportions should be similar for CN8 though probably marginally bigger for each.
It's not really whole countries that worry me, they'll be a bit bigger but the whole of the UK should still fit [v8 will be 185MB], it's long European route corridors being forced to include far more mapping either side due to the larger map tiles in CN8. I get where you're coming from with using mixed tiles from various versions, that's the approach I'll be taking though I would prefer to do that with CS7 than CS6. That's if I can get an unlock for CS7 upgrade along with the unlock for CN8 which is due from Garmin as a free upgrade. If I have to pay for the CS7 unlock then, I'm not sure how much it is ($75 = £40 or is there the normal 'European levy'?), I will consider sticking with a combination of CS6 and CN8.
bumpkin
PostPosted: Sun Aug 20, 2006 9:48 pm    Post subject: Reply with quote
8O
Blimey Strumble!!
Was expecting an increase due to more POIs and maybe a bit more mapping detail but can't fathom why so much more? After all the mapping data should be much of a muchness unless they've added significantly to the detail. On coverage for an entire country tile size shouldn't make much difference, surely? Garmin still only claim 'Coverage for major cities with intertown roads' for Spain in CN8, I would understand a significant increase if this had been upgraded to full coverage.
Might have to push more about getting CS7 as well as CN8.
Chas
BrunoSoares
PostPosted: Mon Aug 21, 2006 11:06 am    Post subject: Reply with quote
You can check the latest Navteq maps that probably will be included in a V9 version at http://www.mapquest.com/
Bruno
Page 2 of 2
22.062 (12 Jun 24)
