Pocket GPS World :: View topic - Finally....adding POI databases to Mio 510 / 710
ravi
PostPosted: Tue Aug 08, 2006 7:44 am    Post subject: Finally....adding POI databases to Mio 510 / 710 Reply with quote
I've finally done it!
Using a few tools that are available on various forums, I've been able to add POI datababes to the Mio. I finished this last night and I'm testing today. Everything appears to be OK BUT the only limitation is that you can't merge POI's with the personal poi's you already have on you Mio. You must add those manually later. All the Mio built in POI's stay unaffected on the machine - it's just your poi's that are wiped. If you don't have many, it shouldn't be a problem! It's a compromise, but it's better than nothing!!
If anyone wants the software and how-to-do-it guide, please PM me. I'll try and get it all done today and email it.
Ravi
WooHooo..
mgrah
PostPosted: Tue Aug 08, 2006 7:52 am    Post subject: Reply with quote
It would be neat to have a link to a download here... Any chance of uploading the instructions somewhere?
ravi
PostPosted: Tue Aug 08, 2006 8:06 am    Post subject: Reply with quote
OK, the lowdown is that one of the essential bits of software was downloaded from a german GPS forum and I can't find the URL anymore to ask the author if it's ok to distribute it. I guess it must be ok or it wouldn't have been on a forum to start with, all the same I feel a little nervous just posting it openly just in case someone get a bit annoyed about it. Thus the PM.
Ravi
WooHooo..
Palexr
PostPosted: Tue Aug 08, 2006 10:02 am    Post subject: Reply with quote
Yes please! Sent a pm.
Can you dowload speed cameras, etc...? What about the icons?
cheers
alex
Cheers,
Alex
Simebaby
PostPosted: Tue Aug 08, 2006 10:13 am    Post subject: Reply with quote
Is this using POIConvert? If so, you can preserve existing POIs by importing the .kml files into an existing iGO.db file (as pointed out by fable on another thread).
Simebaby
PostPosted: Tue Aug 08, 2006 10:14 am    Post subject: Reply with quote
A PM would be great though - I'd like to have a look at your method.
DracUK
PostPosted: Tue Aug 08, 2006 12:11 pm    Post subject: Reply with quote
Good Work Ravi
Please PM me too
cheers
DracUK
toibs
PostPosted: Tue Aug 08, 2006 2:30 pm    Post subject: Reply with quote
Ravi,
You have PM Smile
If this works then i might finally be able to use my 710 PROPERLY!!!!
Thanks Heaps
Paul
rronaldson
PostPosted: Tue Aug 08, 2006 8:07 pm    Post subject: Reply with quote
Sorry if I'm an idiot but what's PM?
Reg
Palexr
PostPosted: Tue Aug 08, 2006 9:22 pm    Post subject: Reply with quote
It's the Private Message button at the bottom of everyone's messages - the one that has 2 silouhettes and says pm Wink
Cheers,
Alex
rronaldson
PostPosted: Tue Aug 08, 2006 11:52 pm    Post subject: Reply with quote
Thanks Alex. Have to get my eyes tested Smile
Reg
Palexr
PostPosted: Wed Aug 09, 2006 12:08 am    Post subject: Reply with quote
Ravi,
Do you know if this would work?
Cheers,
Alex
PostPosted: Wed Aug 09, 2006 2:41 am    Post subject: Reply with quote
I would think so (that is is using POIconvert). Haven't seen any tool yet that would allow you to talk to the SQLite database directly.
The question is - does SQLite support indexing, and if yes, is iGO using the indexes?
Simebaby
PostPosted: Wed Aug 09, 2006 12:25 pm    Post subject: Reply with quote
As far as I can see, using POIConvert on it's own on an iGO.db with existing POI's in it doesn't work - so I was wrong.
Ravi's tools work perfectly - although as stated, you have to add your POI's all in one go - you can't subsequent files without clearing down the existing ones.
The disclaimer comes on because as iGO.db has been re-created, the device thinks you are starting it up for the first time.
toibs
PostPosted: Wed Aug 09, 2006 5:23 pm    Post subject: Interesting.... Reply with quote
It's quite interesting to see the difference in the databases once the PGW are compared....
There's not a huge amount of differences in the two if you compare using the icons. Unfortunately in the past i have found PGPSW database to be around 98% accurate, whereas the Mio ones seem to be around (looking at Bristol and Birmingham areas i.e. the ones i know where the cameras are) 90%.
90% isnt good enough in my view... Sad
Paul
23.054 (28 May 25)
