dereklynch Occasional Visitor
Posted: Mon Aug 07, 2006 7:39 pm Post subject: Where do you input a product activation code on a Tom go700 |
trying to add a map ..... |
Oldboy Pocket GPS Moderator
Posted: Mon Aug 07, 2006 8:09 pm Post subject: |
Which Map are you trying to add?
Is it a non-European Map? _________________ Richard
Darren Frequent Visitor
Once you install the map and select that map then you will be prompted for the activation code if one is needed. _________________ Darren Griffin |
Posted: Tue Aug 08, 2006 2:51 pm Post subject: Where do you input a product activation code on a Tom go700? |
Trying to add an Italy map. Have tried both a manual copy on to the device and then an install using the TomTom Home client.
Can't see the map, can't see where to input the activation code that the TomTom site says is the final step of the install process |
Posted: Tue Aug 08, 2006 7:59 pm Post subject: Re: Where do you input a product activation code on a Tom go |
dereklynch wrote: | Trying to add an Italy map. | Doesn't the 700 already have a Street Level Map of Italy?
If required, the Activation Process comes when you want to use the Map the first time. In your case it might be that you just need to do a pin-in-the-hole Reset. _________________ Richard
gadget_sa Frequent Visitor
Joined: Dec 02, 2005 Posts: 334 Location: Wiltshire, UK
Posted: Wed Aug 09, 2006 11:14 am Post subject: |
Why are you adding a map of Italy? The 700 already has it pre-installed in the Western Europe Map Folder _________________ Steve
iPhone 6 with Western Europe & CamerAlert |
