Pocket GPS World :: View topic - Where do you input a product activation code on a Tom go700
dereklynch
PostPosted: Mon Aug 07, 2006 7:39 pm    Post subject: Where do you input a product activation code on a Tom go700 Reply with quote
trying to add a map ..... Evil or Very Mad
Oldboy
PostPosted: Mon Aug 07, 2006 8:09 pm    Post subject: Reply with quote
Which Map are you trying to add?
Is it a non-European Map?
Once you install the map and select that map then you will be prompted for the activation code if one is needed.
dereklynch
PostPosted: Tue Aug 08, 2006 2:51 pm    Post subject: Where do you input a product activation code on a Tom go700? Reply with quote
Trying to add an Italy map. Have tried both a manual copy on to the device and then an install using the TomTom Home client.
Can't see the map, can't see where to input the activation code that the TomTom site says is the final step of the install process
Oldboy
PostPosted: Tue Aug 08, 2006 7:59 pm    Post subject: Re: Where do you input a product activation code on a Tom go Reply with quote
Doesn't the 700 already have a Street Level Map of Italy?
If required, the Activation Process comes when you want to use the Map the first time. In your case it might be that you just need to do a pin-in-the-hole Reset.
gadget_sa
PostPosted: Wed Aug 09, 2006 11:14 am    Post subject: Reply with quote
Why are you adding a map of Italy? The 700 already has it pre-installed in the Western Europe Map Folder Question Question
Steve
iPhone 6 with Western Europe & CamerAlert
