Type23 Lifetime Member
![](modules/Forums/images/avatars/gallery/starwars16.jpg)
Posted: Thu Aug 03, 2006 8:58 pm Post subject: Maps ? |
Please can someone clarify exactly how maps are set up on the C510D deluxe ? I've installed the software on City Navigator NT+ DVD to my PC and have planned a route with 3 waypoints and used the "transfer to Garmin" option to tx to my Garmin. When I disconnect the Garmin from the PC and start the Garmin I see the 3 waypoints in my favourites but no pre-arranged route ? Is this all the fuunctionality allows you to do i.e plan a route on the PC with multiple Waypoints however when the route is transferred to the Garmin only the waypoints go across ?
What is the difference bewteen a "trace" and a "route" do I need to transfer both ?
Also can anyone tell me if I take my Garmin c510D over to France will I be able to navigate there ? Or is do I need to load / transfer any maps from the City Navigator DVD to the Garmin beforehand ? The instructions are really unclear on this point ! When I used to use my TomTom I knew that I had to install a detailed France map to an SD card. Would really appreciate any help people could give me. Thank you
Rgds |
afterall Occasional Visitor
Posted: Thu Aug 03, 2006 10:01 pm Post subject: Maps |
First question is have you actually transferred any map sets to your satnav.
With my i3 I had to select the map tiles for France that are knew were going to cover my travelling area and then transferred those over. But please note:-
You should also look for threads that address making your maps fully routable. It was'nt that difficult once you have found the info / programs / followed the instruction.
A |
Posted: Thu Aug 03, 2006 11:27 pm Post subject: |
afterall,
I cannot follow that link as it is to a pm. Please can you just cut n paste info into a post. thks |
Beerbellybill999 Regular Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Fri Aug 04, 2006 12:32 pm Post subject: |
City Navigator NT+ should be routable anyway if you use the mapsource loader. I is only metroguide that isn't unless you cheat the system!
Going back to original request Yes you will have to tranfer the maps over to the Gps before you go! _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed) |
swing Pocket GPS Verifier
Posted: Fri Aug 04, 2006 1:07 pm Post subject: Re: Maps ? |
I think the c510d is like the Nuvi, and only supports 1 via point (waypoint). Although Mapsource offers the ability to create routes with multiple waypoints, the device does not support this, hence why your waypoints went across, but not the actual route. It's unclear if Garmin will provide this functionality in the future.
Yes, the c510d only ships with the UK/Ireland map preinstalled, any others countries on the DVD will need installing to either the device, or preferably an SD Card before you will get the benefit of the detailed mapping. |
Posted: Fri Aug 04, 2006 1:14 pm Post subject: |
Swing,
How do you transfer the country map for France across to an SD card available for the Garmin to "read" , this is all I really want and have been searching the forum for an "idots guide" how to do this in simple terms ?
thank you |
