MELennium Frequent Visitor
![](modules/Forums/images/avatars/44197630643a4646455512.gif)
Joined: Sep 25, 2005 Posts: 337 Location: County Durham
Posted: Sun Oct 23, 2005 9:34 pm Post subject: Garmin Streetpilot i3 for dummies. |
Hope this will help all the newbies to the i3.
GARMIN STREETPILOT I3 FOR DUMMIES
1) First make & name a new folder calling it Garmin Streetpilot I3 or similar.
2) Download Garmin Streepilot I3 Firmware 2.60 to the above named folder. (2.60 is latest firmware update at 23/10/05).
http://www.garmin.com/support/collection.jsp?product=010-00434-00
3) Download Garmin POI Loader to the above named folder.
4) Download Garmin USB Drivers to the above named folder. (This is not always required). http://www.garmin.com/support/collection.jsp?product=010-00434-00
5) Download POI Edit to the above named folder.
http://www.poiedit.com/
6) Next make & name a folder on your computer calling it Garmin I3 POI’s & Safety Camera Data or similar.
7) Download the latest POI’s to this folder.
http://www.MaFt.co.uk/garmin/download.htm
8) Download the latest Safety Camera Data to the same folder.
http://www.PocketGPSWorld.com/uksafetycameras.php
9) Connect your 13 to your computer using the provided USB cable.
10) Next make & name a folder Firmware 2.60 or similar then unzip the I3 Firmware 2.60 to this folder.
11) Open the above folder then on Updater.exe & it will automatically download this file to your I3.
12) Disconnect your I3 from your computer.
13) Install GARMIN POI LOADER to your computer.
14) Connect your I3 to your computer using the provided USB cable.
15) Your I3 should automatically open the GARMIN POI LOADER but if not open manually & then select NEXT & it will search & find your I3.
16) Now select NEXT again then on BROWSE to find the folder you made & named earlier where you downloaded your latest POI’s & Safety Camera Data to and then on OK.
17) You can now change the distance & speed to feet and mph if required.
18) Either leave at Express which downloads your POI’s & Safety Camera Data automatically or change to Manual where you can choose to alter the proximity alerts to suite your individual needs.
19) Now select NEXT & it will now download to your I3 if you chose Express, or you can alter the proximity alerts of each POI as you keep on selecting NEXT, if you chose Manual.
20) Once downloaded disconnect your I3 from your computer.
21) For future Firmware updates follow instructions 2, 9, 11 & 12 only
22) For future POI’s & or Safety Camera Data follow instructions 14, 15, 18, 19 & 20 only.
23) Place I3 in car, switch it on, choose your destination & drive away.
24) Finally keep coming back to POCKET GPS WORLD FORUM to read up on anything new in the world of the GARMIN STREETPILOT I3. http://www.PocketGPSWorld.com/modules.php?name=Forums&file=viewforum&f=96 |
Posted: Sat Oct 29, 2005 12:56 am Post subject: |
Since Garmin have introduced there Webupdater,they have simplified the update of there Firmware. I have ammended the "Dummies" instructions as follows:
GARMIN STREETPILOT I3 FOR DUMMIES REV. A
1) First download the Garmin Webupdater & install to your computer. http://www.garmin.com/support/download_details.jsp?product=999-99999-27
2) Connect your i3 to your computer using the provided USB cable.
3).Open the Garmin Webupdater & select NEXT, then highlight the USB button where it will automatically find your I3, select NEXT & it will search & find the latest Firmware for your I3. Finally select NEXT & it will download this file to your I3 then close this program.
4). Disconnect your I3 from your computer.
5) Download Garmin POI Loader to the above named folder.
6) Download Garmin USB Drivers to the above named folder. (This is not always required). http://www.garmin.com/support/collection.jsp?product=010-00434-00
7) Download POI Edit to the above named folder.
8) Next make & name a folder on your computer calling it Garmin I3 POI’s & Safety Camera Data or similar.
9) Download the latest POI’s to this folder.
10) Download the latest Safety Camera Data to the same folder.
http://pocketgpsworld.com/uksafetycameras.php
11) Now unzip your POI’s & Safety Camera Data files to the same folder.
12) Install GARMIN POI LOADER to your computer.
13) Connect your I3 to your computer using the provided USB cable.
14) Your I3 should automatically open the GARMIN POI LOADER but if not open manually & then select NEXT & it will search & find your I3.
15) Now select NEXT again then on BROWSE to find the folder you made & named earlier where you downloaded your latest POI’s & Safety Camera Data too and then on OK.
16) You can now change the distance & speed to feet and mph if required.
17) Either leave at Express which downloads your POI’s & Safety Camera Data automatically or change to Manual where you can choose to alter the proximity alerts to suite your individual needs.
18) Now select NEXT & it will now download to your I3 if you chose Express, or you can alter the proximity alerts of each POI as you keep on selecting NEXT, if you chose Manual.
19) Once downloaded disconnect your I3 from your computer.
20) For future Firmware updates follow instructions 2, 3, & 4 only
21) For future POI’s & or Safety Camera Data follow instructions 9, 10, 11, 13, 14, 15, 16, 17, 18, & 19 only.
22) Place I3 in car, switch it on, choose your destination & drive away.
23) Finally keep coming back to POCKET GPS WORLD FORUM to read up on anything new in the world of the GARMIN STREETPILOT I3. http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewforum&f=96 |
John_2811 Occasional Visitor
Posted: Thu Nov 10, 2005 4:48 pm Post subject: |
Bit of clarification please?
Today I bought a i3 and upgraded the OS to 2.7, down loaded the Garmin POI loader tool and down loaded the Garmin POIs from http://www.MaFt.co.uk/garmin/download.htm
I have read
http://www.pocketgpsworld.com/Garmin%20POI%20Loader%20install.pdf
in this document it says that the speed camera ZIP will have a Garmin folder or the structure, it doesn't. I can see the different files with data structured for types of GPS, but can see no reference to Garmin, only "other".
My question is which of the file/s in pocketgps_uk_sc_oct05 should I extract into the same folder containing the mafts Garmin POIs and BMP files read to be transferred to the i3 with the POI loader tool?
John |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Thu Nov 10, 2005 4:56 pm Post subject: |
john ..this thread is for 'information' to help others ..please dont post questions here... _________________ *************************** |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Fri Nov 18, 2005 3:17 pm Post subject: |
Nice guide, MELennium.
Here's another step to add, it seems that a few people have struck this problem for one reason or another, ie, the unit shipped without ephemeris/ almanac or it was wiped after a reset or firmware update.
If the GPS doesn't get a fix after 2 or 3 minutes then it may take from 5 to 30 minutes to get it's first fix. Take the StreetPilot to a place with a good view of the sky and not obstructed by too many buildings/trees etc. Large outdoor carparks, hilltops or your back garden are good places to try. Don't move the StreetPilot while it downloads the data.
Once it has had a first fix, it should lock on within a minute or two from cold (off for more than 8 hours) or in 10 to 30 seconds from hot (off for less than 8 hours) if it has a fairly good view of the sky. _________________ Gone fishing! |
NoLCD Occasional Visitor
Posted: Mon Dec 05, 2005 2:55 pm Post subject: FAQ it |
Has anyone started or know of a i3 FAQ?
There is lots of good info in the threads that could be brought together in one place.
Mafts guide is great for the POI loading. I'm sure other sections could be generated.
Any thoughts? |
xander Occasional Visitor
Posted: Wed Dec 07, 2005 12:21 am Post subject: |
Yes looks good. I think I'll kick one off and see what happens... |
timbouk Occasional Visitor
Joined: Dec 26, 2005 Posts: 39 Location: Bradford, UK
Posted: Tue Dec 27, 2005 2:25 am Post subject: Re: FAQ it |
NoLCD wrote: | Has anyone started or know of a i3 FAQ?
Any thoughts? |
Come on MaFt, you got nowt better to do ;) |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Tue Jan 03, 2006 6:06 pm Post subject: Re: FAQ it |
timbo_uk wrote: | NoLCD wrote: | Has anyone started or know of a i3 FAQ?
Any thoughts? |
i was thinking of adding it to the site when i next update it :P big brothers eh? who'd have them! |
Posted: Tue Jan 03, 2006 9:54 pm Post subject: Re: FAQ it |
MaFt wrote: | timbo_uk wrote: | NoLCD wrote: | Has anyone started or know of a i3 FAQ?
Any thoughts? |
You spotted the post then! |
Posted: Mon Jan 16, 2006 4:14 pm Post subject: |
I have started something, early days yet. I pour over forums and pull any juicy bits out. Should have something to post soon. Things get in the way... like work! I guess there will be some duplication but as another thread suggest the old timers get miffed at newb's enthuisiasm to get going with their new toy(it was me!) so a single area would help all.
Cheers |
iandee Occasional Visitor
![](modules/Forums/images/avatars/103008783343da28a9ecae3.gif)
Joined: Jan 22, 2006 Posts: 57 Location: Thundersley, Essex UK
Posted: Thu Feb 02, 2006 1:16 pm Post subject: |
hi
fantasic site/forum. stumbled on it as there is a car with the website written all down the side locally! |
poppycat Occasional Visitor
Posted: Tue Aug 01, 2006 6:45 pm Post subject: |
Mnay thanks for the guides. I just got the i3 today, I was dissapointed by the lack of a decent instructions.
I cant find any salelittes at present but I assume that because I am indoors so I try later. However, I see no mention in manual about what the onnector is on rhs I assume thats for an aerial. On rhs near battery no mention in manual of what the slot is, looks empty is this for a sd transcard?
IN manula it also states "plug one end of vehcile adaptor into the usb port of i2/i3. Plug other end in to receptacle of your vehciles". Whats that all about? what usb lead, theres two, one car/usb and usb/pc cable. Am I right in saying its the car power adaptor?
The unit seems to have inbuilt memory form what I can make out. I updated the unit with web updater above from 2.70 to 3.10. Installed usb drivers off CD supplied. Downloaded POI program and poi but when I unzip files and try to put it in the garmin it states not enough memory.
I also cant seem to get the thing to tell right time and no way of getting it to change other than time zone.
Any help would be apprepiated as I need thsi wokring for my hols on Saturday Thanks |
Posted: Tue Aug 01, 2006 7:04 pm Post subject: |
I suggest that you get in your car and have a look at what you've got. It should be fairly obvious which cable is the power plug - you can connect one end to the cigarette lighter and the other to the i3.
If it doesn't get a fix within a minute or two then park somewhere that you have a fairly good view of the sky and wait, it may take 5 to 15 minutes for it's first fix (from then on it should only take a minute or two for a first fix).
The time will be set once you get a first fix. Sometimes the time may be off by 15 seconds, this will correct itself after having a fix for about 15 minutes.
Enjoy! _________________ Gone fishing! |
