juleigh Occasional Visitor
Posted: Sun Jul 23, 2006 12:24 pm Post subject: GATSO for NAVMAN |
I use NAVMAN ICN 650 I just (today)downloaded the latest database including SPEC, Mobile etc. I have gone into POI on NAVMAN and quite happily can import the asc with bmp files for spec, mobile, redlight and temp but every time I try to do the GATSO it says Internal Navman Error.
Can anyone help me please?
Juleigh |
tonys66 Lifetime Member
inspector180 Occasional Visitor
Posted: Sun Jul 23, 2006 5:30 pm Post subject: |
I have been trying to do the same today and get the same result on my Navman icn 630 - OK with mobiles, redlights etc, but internal Navman error on GATSOs. Hope somebody has the answer  |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Sun Jul 23, 2006 5:45 pm Post subject: |
OK, as a workaround, can you open the gatso.asc file in Notepad. Search for GATSO:3542@50 and delete the whole line, then save the file again. I have had it confirmed that this will work on an iCN520, and have transferred it myself onto an iCN550 which would not take the original file. My iCN530 accepted the original file so perhaps SmartST2006 devices are unaffected.
This camera is in the Republic of Ireland so will have minimal impact on what is meant to be a UK database. Perhaps this camera needs to by moved into the European database. _________________ Tim |
Posted: Sun Jul 23, 2006 5:48 pm Post subject: |
OK, I'll try that
Thanks |
Posted: Sun Jul 23, 2006 5:55 pm Post subject: |
That's fixed it.
Thanks very much for your fast help. |
Posted: Sun Jul 23, 2006 6:54 pm Post subject: Thanks |
That certainly fixed it. I am impressed with your service, thank you.
Juleigh |
captureboy Regular Visitor
Posted: Tue Jul 25, 2006 3:12 pm Post subject: |
Why would removing this one camera location solve the problem, is there a limit to the amount of cameras you can have in one file? |
Posted: Tue Jul 25, 2006 7:10 pm Post subject: |
captureboy wrote: | Why would removing this one camera location solve the problem, is there a limit to the amount of cameras you can have in one file? |
Why, we don't know. It has happened once before with one of the speedzoned files and it was fixed in a similar fashion. There may be a limit to the number of cameras in one file but we haven't reached it with the Gatso file. After all, we have over 9000 in the single file. _________________ Tim |
Posted: Tue Jul 25, 2006 7:37 pm Post subject: |
Could the problem be caused by the camera location, that is removed to fix the fault, is not on a map installed on the users sat nav.
I understand the camera location in this latest instance was in the Repuplic of Ireland, this would not normally be a map installed by default on the ICN 510. |
mrcarpcatcher Occasional Visitor
Joined: May 23, 2006 Posts: 9 Location: CANNOCK, STAFFORDSHIRE, UK
Posted: Tue Jul 25, 2006 8:37 pm Post subject: |
No. I have the cameras in Belguim and the euro cameras installed but only put the maps on when i go across the channel as my memory card is to small to have England and France on at the same time. Mine works fine now Tim has said remove the said Irish camera. |
Posted: Tue Jul 25, 2006 9:13 pm Post subject: |
captureboy wrote: | Could the problem be caused by the camera location, that is removed to fix the fault, is not on a map installed on the users sat nav.
No, I don't think so. The original file went onto a 530 (SmartST2006, no Irish maps) but wouldn't go onto a 550 (SmartST2005 Rel2, all EU maps on internal hard drive). To me, this makes it a pre-SmartST2006 issue.
I still have no idea what exactly causes the problem, though.
As I understand it, the downoad has been updated anyway, making the problem moot. Or is that not the case? _________________ Tim |
dizzyfergy Occasional Visitor
Joined: Feb 28, 2006 Posts: 40 Location: West yorkshire
Posted: Sat Jul 29, 2006 1:09 pm Post subject: |
The updated file can not have been loaded ,as yesterday i had the same problem and the quick fix cured it . It seems the faulty camera location is still in the database. |
Posted: Mon Jul 31, 2006 10:35 am Post subject: |
I've been assured that the new DB has been uploaded and it's possible that you're downloading a cached version. _________________ Tim |
jonnie Occasional Visitor
Posted: Thu Aug 03, 2006 11:18 pm Post subject: |
I had the same problem with my Navman 520. Undertook the fix suggested above - and all now loaded in and working correctly. I downloaded the files this morning - so not sure why the problem remains with the GATSO file. Anyway - all working now!! :D |
