Pocket GPS World :: View topic - July 22nd 2006 Speed camera database problem for navman 520
mrcarpcatcher
PostPosted: Sat Jul 22, 2006 7:04 pm    Post subject: July 22nd 2006 Speed camera database problem for navman 520 Reply with quote
I have just downloaded the updated July 22nd 2006 database for speed cameras and installed them on my Navman520.
I use the "consolidated by type" version.
All files were loaded ok.......apart from the "Gatso" files.
When i try to install an "Internal NAVMAN error: if the problem persists please contact NAVMAN support" window appears on my screen, not letting me download the Gatso files. All other files eg "redlight" "temp" etc all load great.
I am using SmartST Desktop 2005 like i used last month and all was ok.
Is any body else having problems or can any body give me any help why everthing else loaded ok apart from "Gatso" files Question Question Question
Tim Buxton
PostPosted: Sat Jul 22, 2006 7:28 pm    Post subject: Reply with quote
I remember this from a couple of months ago with a different file. The Gatso file went onto my 530, though. Can you try changing just one thing in the file, resaving and then trying to transfer it again?
Tim
mrcarpcatcher
PostPosted: Sat Jul 22, 2006 7:32 pm    Post subject: Reply with quote
Thanks for quick reply
Will try altering file slightly
mrcarpcatcher
PostPosted: Sat Jul 22, 2006 7:48 pm    Post subject: Reply with quote
Have tried altering file, still will not download.
Then re-downloaded file and over-wrote old file, but new file still will not let me download it. Sad
Any more ideas will be greatly received
mrcarpcatcher
PostPosted: Sat Jul 22, 2006 8:09 pm    Post subject: Reply with quote
I have tried downloading the old file (june version, i saved it as a back up incase a problem arose) and i can load that Gatso file ok, but still new July version will not work Confused
PostPosted: Sat Jul 22, 2006 11:54 pm    Post subject: Reply with quote
I have made some changes to the original file on the server for the Gatso. If you try again this should be cleared up if it was the same issue as last time.
mrcarpcatcher
PostPosted: Sun Jul 23, 2006 12:07 am    Post subject: Reply with quote
Still no luck. Confused
Have re-downloaded database for Navman and tried to "save to device" but it will not let me download "Gatso" file, other files i can still download.
Has anybody been able to save it to Navman 520 Question Question
Tim Buxton
PostPosted: Sun Jul 23, 2006 12:39 pm    Post subject: Reply with quote
Just to update, the file I successfully put onto the 530 will not go onto the 550 in the same format.
Tim
mrcarpcatcher
PostPosted: Sun Jul 23, 2006 1:02 pm    Post subject: Reply with quote
Thanks Tim
The new file you e-mailed me worked first time when i downloaded it.
Thank you for your very quick response to my problem
Many thanks Mark :D
inspector180
PostPosted: Sun Jul 23, 2006 5:38 pm    Post subject: Reply with quote
Hi Tim,
I'm having exactly the same problem trying to download GATSOs to my Navman icn630 (in the past hour). Everything else loads OK.
I'm trying this website out for the first time and I understand I'm only allowed one download of speed cameras on the monthly sub paid.
Can I download a modified GATSO file again if it has been changed?
Hope you can help!
inspector180
PostPosted: Sun Jul 23, 2006 5:57 pm    Post subject: Reply with quote
There's a fix in place now. See the other thread GATSO for Navman.
Thanks for the help
Tim Buxton
PostPosted: Sun Jul 23, 2006 6:03 pm    Post subject: Reply with quote
The other thread is here.
Tim
JockTamsonsBairn
PostPosted: Sun Jul 23, 2006 8:41 pm    Post subject: Reply with quote
Hope you can help!
I'm sure that the monthly subscription allows you to download as many times as you like within a month.
At the moment, the database is generally only released once a month, but the suggestion has been made that this will be increased in time. I think that the 2 most recent releases were about 3 weeks apart.
Jock
PostPosted: Mon Jul 24, 2006 12:38 pm    Post subject: Reply with quote
Hope you can help!
Indeed you can download as many times as you want while your subscription is active.
johnszs
PostPosted: Mon Jul 24, 2006 9:31 pm    Post subject: Reply with quote
i am having this problem too Sad
22.055 (29 May 24)
